Lion miter trimmer knives
Dale Lenz
>Just unpacked a LMT and the knives need resharpen, anyone have them sharpen by their local sharpen shop? Happy with results? Mine has a few small nicks, so I'm not interested in sharpen them myself.
TIA,
Dale
Dale Lenz
TIA,
Dale
Re: Lion miter trimmer knives
Larry Marker in Alabama
>I'd send them to Scott Whiting. He hangs out here and has an excellent reputation for doing good work and charging a fair price.
scottsharpaz@qwest.net
Larry
Howard Norman-Prescott, AZ
>I talked to Scott a few months ago about sharpening Lion Miter knives. At that time he didn't do them. He would have sent them out to another shop in Phoenix according to what I remember. I talked to those people but never sent my knives there. I also went online and sent an email to the address on the Lion miter web page. The guy wanted $50 to sharpen then. Didn't do that either. So my LMT has the knives removed just resting on a workbench. I need to get them sharpened.
Howard
Scott Banbury
>Call some local picture framing shops and ask them where they get their "chopper" blades sharpened.
Re: Good idea, Thanks!
Dale Lenz
Sharpening shops
>Many sharpening shops routinely grind straight knives for paper shearing equipment. If your regular blade grinder doesn't, ask him who does. He'll know for sure.
Re: Sharpening shops
Dale Lenz
>I'm going to drop them off in the morning when I drive through Tulsa and will pick-up in PM while drive back through. Sharpening guy told me 15~25 dollars, hope he meant, for both knives.
Called a local frame shop and she told me they take theirs to Houston, TX. All day drive from here! Me think they thought I might compete with them, arrg, *&%#@'s.
Thank to everyone that offered advice. Dale
Re: Sharpening shops (and stealth gloat)
Scott Banbury
>I have a friend here in Memphis that I got to know when he used to come by the frame shop I was managing to pick up my Morso chopper knives. These knives need to be razor sharp to cleanly cut the very brittle laquer finishes on many frame mouldings.
Since I opened my custom woodworking shop, I take all my straight kives to him. He has several straight knife grinders.
The one he usually uses on my planer and jointer knives is about 8' long. The knives are all held in line and the grind depth is adjusted with precision blocks of the same dimension under each blade in the set to maintain perfect balance.
His big grinder is 48' long to accomodate the shearing knives used by several paper and panel manufacturers in the Midsouth. He'll have to use this one when he does the 4 knives for the 36" finish planer I'm fixin' to get.
Almost every good sized city has a shop with this sort of setup--you just gotta find them.
Re: 36" Planer!!!
Dale Lenz
>You got a 12" cement slab to set that anchor on, : ' >...jealous
