Have a question? Ask Woody!
Upgrade to Clamp cart
Marty - St. John's, Newfoundland, Canada
>I made the clamp cart from the plan posted by Tony Haukap. It was very easy to use and works great. Thanks Tony. But I was thinking about adding a sliding panel in the open area as shown in the side view. My question is how would I attach the sliding panel to allow it to slide easily? Would I use heavy duty drawer slides or is there and easier solution. I want to store the small C-clamps, spring clamps,etc. on this pull-out panel.
Thanks in advance ...
Marty ...
remove the 99 for email
Re: Upgrade to Clamp cart
Rod Peterson -- Ormond Beach
>Heavy duty drawer slides is exactly what I thought before I even got to where you suggested that. Depending on what the actual dimension is between A-frames you could attach them directly to the stiles, or you could attach cleats between the A-frames and install the slides on them. That way you could have the shape of the sliding box/drawer/panel the same as the slope of the A-frames, maximizing usable space. Probably no reason you couldn't have a couple of drawers like that.
I like the idea and may retrofit it to my rack. I need some organization for some smaller items like corner clamps which don't lend themselves to hanging on the rack otherwise.
Rod
Robert Henderson
>How about building and inverted t-shaped insert with triangular gussets on each end for support. Then you could use the type of full extensions slides that mount on drawer bottoms, eliminating the need to build cleats and you could mount clamps on both sides of the upright and lay oddball stuff on the base.
>I have drawers in my lathe cabinet with full extention rails on them. They work fine except that they get saw dust and other crud in them and I have to blow them out occasionally. Be prepared.
Doug Reynolds in Seattle
>Marty: This looks a lot like the Norm Abrams model I built to his video/plans. If it is and you add dowel at the A-frame for clamps and such, one problem I had is that I cut the dowels per the plans and they are just a little too short for three of my spring clamps. They keep falling off. Wish I had tried it for size before I glued them in.
