Re: Cost of building a garage
Ray Newman
>FWIW: In �01, we were in a similar situation: new house & new shop (30�x36�), as well as retirement. Depending upon your expertise & energy level (as well as a high frustration toleration), you maybe able to do some of the work yourself. Here�s a few thoughts based on our experiences�.
1.)Check w/ the local bldg dept about any restrictions as to the size of any out bldgs. If you�re bldg in a community, also check on CCR�s, ordinances, etc. Don�t take a contractor�s or a Realtor�s word�they are out to sell property.
2.)Design the shop to fit in w/ the house�same roof design & materials, same siding, windows, etc. This will also enhance the value of your property. In our 7 home development, we were the only ones to do this. A few other homeowners have built out buildings/shops/extra garages w/o thought to design, overall size, materials, etc., & it shows. Thank God I don�t have to look @ them. Our shop is located so I can look @ the driveway when the door is open, & all tools face the driveway�so no one approaches unnoticed�.
3.)Insulate the bldg w/ the maximum amount of insulation possible. Insulation is cheap compared to ever increasing energy costs. As one poster said, frame w/ 2X6. Install highly efficient windows. Make sure the slab is insulated & has a moisture barrier. If you plan for a roll-up door, get an insulated unit & a garage door opener. Makes a world of difference when it�s raining & you need to load/unload.
4.)Install a highly efficient heat/cooling(?) system. I installed a � Hot Dawg� ceiling mounted 75K BTU propane fired furnace controlled by a low temperature thermostat. It does not have a standing pilot light. System takes air from shop to keep the fire going. Fumes & water vapor vented outside. I keep it at 45-50 degrees in the. Since I use water finishes, there is no real problem w/ this unit. The fan will throw the warm air 40 plus feet & in no time the shop is up to 65 degrees or so when I work there.
5.)Security. Windows about 5-6� from the floor keep our prying eyes. Will also provide more storage room underneath the windows. Have shop wired for telephone & alarm system. Install a phone that can be reached from siting on the floor & has the keypad in the handset. This way if you injure yourself and can reach the phone, you can use it. An intercom hooked up to the house might be worthwhile. I consider TV & a computer to be a dangerous distraction.
6.)Electrical: receptacles 50-52� above floor --sheet goods will not block them. If you have children/grandchildren, it might be worth while to install a master cut out to for all but the lights when you�re not there. Put in a large shop panel in a convenient location. Take pictures of wiring before closing up walls. Had the electrician install a 220V 50 amp for a future welder if I ever get one.
7.)Lights: if installing florescent, look @ Fine Wood Working, # 153, Winter 2001/2002, which has an article on the high efficient T8 lights & how to plan lighting needs. Put lights in a series of switches/banks so you don�t illuminate the whole shop when you don�t need to. Skylights (speaking from personal experience w/ prior residence here) are nice, but they are a place where leaks can/will start, are hard to seal up (if they open) & depending on size, are an invitation for miscreants to enter your property.
8.)Wood floor is more comfortable & tool friendly.
9.)Make a large scale drawing of the shop & cardboard cut outs of the tools & benches. Really helps to aid in tool placement for efficient workflow.
10.) #9 will help you plan for an efficient dust collection system, which is a God-send if you work when the shop is closed up. You might consider a separate room for the DC & air compressor to deaden the noise. Some choose to vent the dust outside, but some localities prohibit this & you�ll also being removing warm/cool air from the shop.
11.)Interior walls/ceiling: I like drywall painted white to reflect light. Shop cabinets are hung via French cleats. Ceiling ht. is a matter of preference & what you intend 2 do.
12.)Keep the shop only for you. My spouse & I agree that I don�t put anything in her doll studio & she doesn�t or temporarily place anything in my side of the shop. The �temporary� & seasonal storage items never leave. This has happened to a neighbor.
13.)Our shop was plumbed for a bathroom, but only a deep �slop� sink was installed. If you have a bathroom, the tax assessor will love you.
14.)If you have walkways placed around the house & shop, install 4� or even larger diameter PVC pipe in the ground @ the corners & other locations before the concrete is poured. That way you always have access if you want to run an irrigation system, outdoor lighting, etc.
(Saw a shop about 10� from the garage & the owner had a buried piece of 6� PVC connecting the 2. In the pipe, he snaked an air compressor hose, so he could fill the truck tires w/o moving the vehicles outside.)
