bandsaw tires, what kind to buy?
gary s clarke
>I need to replace my delta 14 inch bandsaw tires and have 2 options. Rubber or ultra blue urethane. Which would be better as to ease of installation and longer lasting and which run smoother?
thanks
Re: bandsaw tires, what kind to buy?
Gary Evans Tallassee, TN
>I used the blue urethane on my Delta 14 inch. I don't recall having a hard time putting them on, but it's been over a year and I don't recall much that far back anyway. At least it wasn't such a chore that it stood out in my memory.
I can't speak with authority on the smoothness issue. The rubber tires that were on it when I got it were hard as a rock. It seems pretty smooth to me, though.
Gary
Howard Acheson
>It really comes down to longeivity vs price. The OEM rubber tires should last at least 10 years--mine were 14 years old on the Jet I just replaced. The price for the OEM tires is about 1/2 the price of the urethane. The urethane tires are generally thought to last forever.
Finally, while some seem to have no problem installing urethane tires, I have heard of some where it was quite a chore. Of course, they may not have been following directions on how to go about it.
wilbur
>I recently went through the bandsaw tire replacement process. I went with cheap orange urethane tires. Here were the pros and cons as I saw it:
Price: Rubber tires are cheaper. I know many people will stop reading this post right here. :@)
Installation: Urethane tires are harder to stretch to put on the bandsaw (I used spring clamps and dowels, as if I was changing a bicycle tire), but you have to glue rubber tires in place, which is smelly and messy.
Performance: It depends. Bandsaw blades run best on a tire that is slightly crowned. If your bandsaw wheels are crowned, the tire will follow the crown. But if your wheel is flat, you'll have to put a crown on the tire itself, which is easier to do on a rubber tire than a urethane tire.
Durability: Most people think that urethane tires last longer, except for some who maintain that they will break down faster.
Best price I find... *LINK*
Hoa Dinh in Alameda
>is from Hartville Tool (link below).
I have a set for a few years now - no complain.
Enter promo code "Woodnet15" for 15% off (does not show up in the total, but will be deducted from invoice).
-- Hoa
Urethane Band Saw Tires
