Wood Shop Sound Proofing
Bruce Evans
>I am in the process of expanding my wood shop to encompass most of the basement and in doing so have a unique opportunity to get some remodeling done at the same time. I have open joists with a tongue and groove sub-floor overhead (hardwood on top of that)and a wonderful wife who hears all from below!
My thought was to use Homasote and attach it to the underside of the sub-floor and then caulk it at the seems and joist edges. All the exposed wood and Homasote would then get a liberal dose of white paint and the lights would follow - using the cavities to keep them recessed and out of harm's (i.e. me with a board) way.
I should stop much of the high end frequency noise, some fumes from going up and stop the dust that sometimes sifts down from above.
My questions is concerning placement of the Homasote panels. Are they better glued/screwed to the sub-floor or should I use strapping and create an air space between the two? Perhaps there will be nominal difference between the methods - but I am counting on you to help me decide - strap or not to strap, that is the question.
Thanks in advance for the input!
