OT - buffing motor hookup
Tony Shaftel
>I just acquired a used washing machine motor to power a buffing wheel. No idea how to connect power to it, and no hits on the internet for any of its numbers. Thought I'd post the particulars here in case someone can suggest a next step:
Make: says GE on tag
HP: 1/2
Speeds: 1725, 1140
Numbers on tag: 5KH61KW2516FS, FV-2011, 9836BMC2, B0603
Shape: square, with clutch/pulley unit
Mount: vertical mount only (clutch down?)
Connector: six male spade terminals, harness is missing
Numbers on connector: 3ASM21B11C1, 9836M, 61C350000AB-2
Don't know if it has/needs a starting capacitor.
Is there any hope, or should I continue my search for a motor?
TIA,
Tony
Re: OT - buffing motor hookup
Dave Chatham
>Most washing machine motors are an open winding configuration. The hot wires are exposed when the motor is powered, this is fine when enclosed in the washer cabinet. Not so fine when used for a buffer, keep looking, (look in the wifes dryer for a more suitable motor)!
Ha ha!
Tony Shaftel
>"...look in the wifes dryer for a more suitable motor..."
What, am I tired of living? :-)
Yeah, I noticed the exposed wiring.
Re: Ha ha!
>Not positive, but I believe that motor is made to run in the vertical position only. The bearings are designed for that position and will not last long if you turn it horizontal.
Yup
Tony Shaftel
>It does have to sit shaft pointing down. With a reasonably long belt the driven shaft can be turned 90 degrees, I understand. But along with the exposed coils that's already two strikes against this baby. Oh well, it was free.
Tony
Don Evans
>Go to:
www.surpluscenter.com
they have lots of motors in the power range you need for less than $50.00.
Don
Re: OT - buffing motor speed
Norman (Metcalfe, Ont.)
>I too am interested in setting up a buffing system for my
wife's jewelry making.
I have a 1/2 HP, 1725 RPM motor from a bandswa motor swap,
it even has a in-line switch. Only issue is it is a single shaft,
but this should suffice.
Is the shaft speed ok for a buffing wheel?
Does it need to be faster or slower?
Norman
Good speed
Tony Shaftel
>That seems to be the recommended speed for a good range of buffing wheel sizes, assumming the wheel is directly attached. You can also get buffing arbors--I'm thinking of the Shop Fox unit--that consist of a housing with a long shaft coming out right and left for holding two wheels at once. The shaft has three pulleys on it inside the housing. Any 1/3 HP or higher motor with the proper drive pulley could be used with that. Takes up a lot of room, though.
Denis Ch�nard, Orl�ans, Ont.
>Norm, you could use this to have two wheels mounting points:
http://www.leevalley.com/wood/page.aspx?c=2&p=32960&cat=1,43072,45939
DC
Too slow for metal *LINK*
Tim Greif - West of Chicago
>You need at least 3400 rpm for metal buffing. One of my other hobbies is brass restoration. Juat buy a cheap 6" grinder that runs 3400 rpm. If you really get into doing this, you'll probably want a real buffer with longer shafts. The link below is a good one.
Metal Buffing
Norman (Ottawa, Ont.)
>Denis,
I saw the mandrel ealrier also. I like the idea because the motor is separate and there is less likelihood of getting buffing contaminants in the motor itself, since this particular motor is not a sealed motor.
It is a good idea and I could use a larger pulley on the motor shaft to have an increased mandrel shaft speed.
I'm also considerring the grinder option, modifying it for buffing wheels. It has a sealed motor already and is the correct speed - 3450 RPM.
Norman
Re: thx for link !
>Tim,
Thx for the link, it answers many other questions I have !
Norman
Re speed
Tony Shaftel
>Sorry, missed the fact that it was for metal jewelry, not wood pieces.
