Re: Thanks for your help guys-re 220 converter
Al Stokka - Cambridge, Iowa
>"I am still interested in how these converters work if they don't tap a hot from each side of the box as mentioned."
Bob,
The device does tap a hot conductor from two separate circuits. That's why there is an indicator light on the device. If the two source circuits are not 180� out of phase, the indicator will not light, telling the user that the device is not hooked up correctly.
Running wires from a breaker panel with a 230V breaker accomplishes the same thing. If you have two, open, adjacent slots in your breaker panel, you should use that method to gain a 230 circuit. Likely cheaper in the long run than buying the converter.
Al
