Mahogany walls - what to do>
Dan Manturi
>My stepson is about to buy a home that has t&g mahogany walls all over the living room and dining room The Kitchen has mahonagy plywood cabinets and walls. This is high quality, but wow is it dark. I do not know what the finish is on any of this.
While the look can be dated, it would be difficult to buy all this mahogany and proper decorating could make the rooms look quite rich. That said, how would you care for / refresh / refinish these surfaces?
Thanks.
Dan M
Re: Mahogany walls - what to do>
Doug in Denver
>Some pictures might help. How dark we talking? Mahogany darkens naturally, but it can also depend on whether it was stained when it was first finished, and whether the finish itself has darkened. What I have found is that results with refinshing mahogany are totally unpredicatble. I had a neighbor with a chest of drawers that was that dark purple color, and no matter how much chemical finish remover he used, it never really got lighter. And using any sort of chemicial on whole walls indoors is not practical.
Dan Manturi
>I doubt the walls were stained. The place was built in 1957 and all the wood was installed then. I think for the dining room and living room, the darkl color and stonework is fine, but for the kitchen, it seems overly dark. There is almost too much to sand. Cabinets and walls all mahogany!
Sand it
>Dan, nothing else is going to get you down to brighter wood. It could be tricky, though, if the oxidation has not penetrated equally everywhere. I'd find a concealed section of paneling and sand it with whatever grit is appropriate to get down to bare wood. Err on the fine side. If there is a film finish, use a friendly stripper like Circa 1850 varnish remover first. Sand it until it brightens a bit, then topcoat it with whatever. I'd suggest a wiped coat of thinned blond shellac for ease of application and resistance to darkening. If you want a bit more build, you can put another coat of shellac on it and then a wiped coat of oil or varnish. But, don't put oil or Danish oil directly on the bare wood if you want to keep it bright longer.
Re: Sand it
Dan Manturi
>I was figuring on a stripper. Circa 1850 - used that years ago, good stuff! What to use as a finish and to sand it or not was my mental dilemma.
Thanks for jumping in, Ellis!
Dan M!
Mike Fitterling
>It might be cheaper, and a whole lot easier to consult with a good interior designer. They should be able to help mitigate, through decorating, that darkness without having to redo all the woodwork. Very light carpet, different lighting, furniture, a white countertop, that kind of stuff. Redoing a whole house worth of woodwork is a LOT of work, DAMHIKT.
Good luck!
Mike
Doug in Denver
>And I have to say that depending on how it is fastened, I would be tempted to to at least consider pulling it down, planing it just a hair, and reinstalling it then finishing. That will guarantee the lightest possible finish. Seems like a ton of work, but about the time you have a bunch of stripper spread around and still looking forward to hours (or days) of sanding, it might be very appealing.
Dan Manturi
>gents,
Thanks for both suggestions. The stuff in the living and dining rooms it T&G, and planing is an interesting thought depending on what is under there. The decorating angle is a primary approach for this areas - perhaps some stripper and light sanding and a good finish just to restore the wood. Kitchen is a hole different story and I am thinking perhaps Performax sander time for anything I can pull off the walls.....
Just figured out how I can get the wife to let me buy one!
Thanks again.
Dan M.
Tom Stockton
>You'll be frustrated with a drum sander if you don't strip off the old finish first. In my experiance with my delta, finish and glue tend to clog the sandpaper fast and I think old finish would be worse.
Tom
Michael Wilkins
>The parents of a co-worker lived in a home with T & G mahagony paneling on the den walls. I offered to remove it and replace it with drywall/paint if they ever got tired of looking at it.
This is a lot of woodwork to refinish. Good luck.
Dan Manturi
>I agree. We are going to restrict the major work to the Kithcn area. Living room and Dining room we will merely hit with some light sanding, a wipedown with a tack rag, and some wipe on like perhaps a blonde shellac as Ellis suggested. The walls do not look like they are finished in this area.
It seems in some circles, this mahnogany look is still quite popular. I was surprised.
Thanks to everyone who responded.
