Powder Coating equipment?
>I've seen these in action. About 10 years ago a furniture company came into our office and repainted several dozen steel filing cabinets. They used a powder coating system.... hooked up each cabinet with a copper wire and then sprayed the new coating. It was amazing. They did it in the office and there was no mess or anything on the carpets or anywhere. And the finish was almost the same as the new cabinets.
I thought I read somewhere that someone had a commercial system like this for sale. Perhaps it was Craftsman. I thought it was under $200. Does anyone know anything about this yet?
I'm wondering if there are any systems that can be purchased for home use. I thought perhaps the technology was still immature and that the Craftsman may be a first generation and that it may take a few years before they get good enough to buy.
I've got a bunch of steel frames and machinery that I'm sand blasting and want to repaint and thought that perhaps powder coating would be the way to go. If I sandblast it myself and then take it someplace to get it powder-coated, I might be spending as much as getting the equipment to do it in my garage.
If anyone know anything about these, let me know. Thanks.
Happy Woodworking!
Re: Powder Coating equipment?
Eastwood has one also.
Ray Thompson - Middletown,IN
>but it is a bake on system as well as the Sears.
Ray
Gary Camp, Bend, Oregon
>Mark
If there was no oven I don't think it was really powder coating. I did have a bunch of metal lockers repainted where I work. The painters did use an electrostatic process, but it was not a baked on powder. A lot less mess, very good finnish, more durable than regular paint, but not as durable as baked on powder. I don't know about home owner versions.
glc
Oh... it needs an oven
>Thanks.
Yes, that's the Craftsman I saw earlier.... I must have seen it reading a magazine during a loooonggg wait at the HD checkout;)
I didn't realize you needed an oven. The system they used for the filing cabinets didn't require an oven. Maybe it was some sort of hybrid system or something.
Happy Woodwrking!
Re: Oh... it needs an oven
Howard Acheson
Those systems were generically called "eletro-static coating sysems". The coating was/is a liquid. The liquid and substrate are negatively and positively charged so the liquid is attracted to the substrate. The objective is to minimize or eliminate overspray. I used the write the corporate contract for our company.
"Powder coating" is something different. The powder is always just that-a powder. It to is electro-statically applied but it requires heat to "melt" the powder into a semi-liquid.
Scott Greaves in Blackfoot Idaho
>Hi Mark,
Powder coating does require a "cure" process. For small items this would involve baking in an oven (not your home oven). For larger items they use an infra-red curing lamp.
The powder coat system available from Harbor Freight is pretty good for home use. A lot of penturners use powder coating for various uses with pen kits, and we bake them in a toaster oven. The infra-red lamps are available to a homeowner - check on Ebay - but the cheapest one I've seen is about $350. Car and motorcycle enthusiasts use powder coat when building up custom machines, so look to some of those hobby sites for more details.
Hope this helps!
Scott.
Thanks all....
>I've got a several antique motorcycle frames, and a gocart frame and a few antique cast iron machinery stands that I wanted to refinish. None of which would fit into an oven.
I guess you're (all) right. The filing cabinets must have been done with an eletrostatically charged paint system, and not powder coating.
I guess I'll look for a local powder coat finisher, perhaps automotic or some industrial service center aroudn here. If anyone has any pointers let me know.
I'm assuming that it would work with cast iron too. I have this beautiful old Newton belt sander that is on a really heavy cast iron stand. I was going to paint it, but wanted to try something better.
Happy Woodworking!
A.J. Hamler
No reason you can't
A.J. Hamler
>You can use a standard kitchen-type oven, toaster oven, etc. In fact, when Sears demonstrated the system for an editor's conference a few years ago, they used a large toaster oven. The media material they gave us showed it being done with a standard kitchen stove/oven, but all the photos clearly showed that the oven was in a basement setting, not a kitchen. However, in the interests of not being sued if you set your house on fire, Sears and others really don't want you baking paint and stuff in your kitchen.
A.J.
So I guess you need to
Don Henthorn
>buy a cheap old used range and install it in your shop. Then you can powder coat of others as well. Course you'll have to lay money aside for your electric bill.
Lee Gordon
Re: Thanks all....
Lee Gordon
>Keep in mind that, while you'd have to cart your stuff to the powder coater, an electrostatic painting company will come to you.
Craftsman on sale for 149.99 until 03/17/07
Ray Johnson
>Craftsman Powder Coat System
Sears item #00917288000 Mfr. model #17288
Sale Regular
$149.99 $189.99 Save $40.00 thru 03/17/07
A.J. Hamler
Or gas bill
A.J. Hamler
