Steel City TS
Steel City TS
Steel City TS
Bretton Wade
>Hi Folks, I have a new Steel City tablesaw, the 3HP "hybrid". I've been setting it up, and run into a few problems. This is my first table saw (I'm a galoot), so I'm largely ignorant of the mechanical details.
In checking the miter gauge slot for parallelism with the blade, I'm getting that it's 0.008" out of alignment using a dial indicator mounted on a jig that runs in the miter slot. This is many times higher than the suggested manufacturing tolerance, but the advised procedure for correcting it is remarkably imprecise. Basically the directions say "loosen these 4 bolts and adjust the table to be parallel." That's a simple instruction, certainly, but a 1/8" adjustment at the table edge results in something like 0.05" movement at the slot. How on earth can I get within 0.003" as every article I've read seems to suggest is the tolerance?
I've tried searching this website for help with more precise procedures, but obviously I don't know what to search for because the result list is far too big for me to process. Yet... the references I see suggest that the knowledge about how to do this right is common lore. Can somebody help clue me in?
Re: Steel City TS
Re: Steel City TS
>Bretton If you have a dead blow hammer tighten the screws a little and tap on the table to get it into alignment. I had the same problem with my Powermatic. The adjustment is too course.
Re: Steel City TS
0.008" ???
SanMan
>If you see no way to get within 0.003", how do you expect to get within 0.008"?
It's a Table saw ....not a milling machine. Your cutting wood, not metal...right?
I dont think this is anything to get uptight about personally, but then again I dont shoot for machinist specs either.
YMMV,
SM
Re: Steel City TS
Re: Steel City TS
Phil Thien
>Yeah, what John said. You are just nudging it w/ a rubber mallet. It is done all the time, you will be amazed how easy it is.
Re: Steel City TS
Re: 0.008" ???
Bretton Wade
>Yeah, I've heard that viewpoint, but that's not the argument I'm looking for. ;)
The gap I'm describing isn't small or hardly measurable, it's clearly visible to the naked eye. In addition, the saw blade obviously drags on the back side of the cut.
My question: is a set of hammer taps really how you get to 0.001" tolerance?
Re: Steel City TS
Re: Steel City TS
Bretton Wade
>I'll give it a try...
Re: Steel City TS
Re: Steel City TS
Mike Jurnigan in Suffolk
>I would back off the bolts, then snug them back up. I would use a ball pein hammer and a brass bar to tap the part that needed to be moved. If it moves too much, move it back the other direction and snugg up on the bolts a little more and repeat. You can easily move items like this in .001" increments. Have done it a many a time aligning noise critical machinery on Submarines. Former Subsafe qualified Outside machinist by trade.
Mike
Re: Steel City TS
Yes, that is exactly how you do it.
Ray Thompson - Middletown,IN
>I doesn't matter whether it is a $1000 saw or a million dollar special machine. You just snug up the bolts and tap it into the precise location you need, then tighten the bolts. Now, on the million dollar machine you will probably drill and ream for a tapered dowel once you get it there, but the process is the same.
Ray
Re: Steel City TS
Re: Steel City TS
Bob Lang
>I think it's easiest to loosen 3 of the bolts, and get the remaining one snug but not real tight.(technical term from my tool and die maker grandfather)
That way the top will pivot in a somewhat predictable manner as you smack it around.
Bob Lang
Re: Steel City TS
Re: Steel City TS
Stuart Hough
>That's exactly what I did on my Craftsman and it worked perfectly! After a couple of taps and meauring, you'll get a feel for how hard to hit it to move it a predictable amount.
Re: Steel City TS
Re: Steel City TS
Stuart Hough
>That's exactly what I did on my Craftsman and it worked perfectly! After a couple of taps and measuring, you'll get a feel for how hard to hit it to move it a predictable amount.
Re: Steel City TS
0.001" Followup (was Re: Steel City TS)
Bretton Wade
Many thanks to all the people that helped me out. It was indeed rather straight-forward to loosen the table bolts and use a soft-faced hammer to bang it in little increments. It took me about 15 minutes, and my imagined frustration at overshooting constantly back and forth never materialized. The dial indicator now hardly moves as I shift across the blade surface.
I will (almost) never worry about this again...
I notice that the blade gets thinner toward the center, which makes it hard to think about how to verify it is square to the table due to a gap showing on both sides (see bad ascii art below for an exaggeration), any ideas for that?
              ++ ________
  Square->    ||   \  /    <- Blade
-------------------------------Table----
Thanks again!
Re: Steel City TS
Re: 0.001" Followup (was Re: Steel City TS)
Bill Howatt
>IIRC, I used a small precision square that was on the flat. Reality is that you want the cut to be square. Adjust it best you can and then verify with a test piece that it is indeed a square cut.
Bill
Re: Steel City TS
David Yoho
>If I'm reading your concern about squaring the blade with the top of the saw table right, this is very simple. I use a 4-inch Starrett square I keep in my apron pocket to check it. You just need to remember to only place the edge of the blade of the square against the plate of the saw blade - not the teeth.
Even though I have the 90-degree stop on my saw set fairly accurate, there are times I double check the blade using my square before making certain cuts.
David
Re: Steel City TS
>Brett I had the same problem. all my blade have a recessed are. I put a good solid rule againts the outside teeth of the blade and ran my dial indicator down this. Another good way to do this is to mark one tooth. rotate that tooth to the front of the table and measure it. Then rotate the same tooth to the back and measure.
A final check, and the one that truly counts is to crosscut a longer piece that has parallel edges. flip one 180 degrees and put them together. This doubles any error. If they fit your done.
Re: Steel City TS
Howard Acheson
That's not the way to do it. You do not use the blade surface as the reference. Blade plates may not be flat and if you have overtighted the blade nut, you can be dealing with a distorted blade.
The reference is the same tooth positioned at the front of the saw and then the same tooth positioned at the rear. Raise the blade all the way. Use you gauge to determine which tooth edge sticks out the most. Mark that tooth with a magic marker or pencil. Now move that tooth front to back until the the measurements are equal or within 0.003". You should be able to get it to 0.002 - 0.001 with a little patience.
Re: Steel City TS
might also want to check
Robin Corell in Atascadero, CA
>while you are set up and have a blade tooth marked it is also a good idea to check with the blade tilted at 45. it is critical to measure at the tip of the tooth and with the tooth level with the table surface. if there is any discrepancy consult the manufacturer for directions to correct. it is not as simple as the prosess you are using to allign the miter slot.
enkoy your new saw,
Robin Corell
Re: Steel City TS
Re: might also want to check
Dave Morris
>Robin (or anybody), I'm not familiar with these new "hybrid" saws. Guess things have changed over the last few years. Do they have the same problems with alignment on 45� cuts as contractor style saws? As in, the motor weight pulling the blade out of parallel with miter slot?
Dave--- who drove himself almost crazy trying to fine-tune his Powermatic contractor saw
Re: Steel City TS
>it is generally not the motor weight pulling it out of allignment. It is hard to describe without pointing to a drawing or the actuall parts, or at least in my mind. the out of allignment in the 45 position is usually caused by the trunions being shimmed incorectly. on a contractor style saw the trunions are bolted directly to the table and on a cabinet saw, as I'm sure everyone knows the trunions are bolted to the base. in both cases there are shims at each monting point. these are ultra thin washers and when not needed are between the casting and the head of the bold and when needed are between the trunions and the mounting point, ie.. table or base.
to determine which point needs shiming you need to determine which mounting point for the trunions needs to be moved by removing or adding a shim to get the blade to move in the desired direction. the amount of shimm is a guess. to check you have to reallign the table with the blade at 90 because you will lose that allignment when removing the table to make the trunion adjustment. then check the angle. It is likely you will have to repeat this process seveal times to get good alignment in both directions but it is possible.
I have done this on a delta contractor saw and a powermatic 66. with a contractor saw it is easiest to remove the motor and turn the saw upside down, right side up, upside down.... with a cabinet saw it is easiest to have a friend handy to help move the table on and off repeatedly. If it happened to me on a new saw I would likely send it back or return it.
Robin Corell
Re: Steel City TS
Shims? What shims?
Dave Morris
>Thank you for a very enlightening answer, Robin. As I look back on what it took to tune my saw, there were NO shims for the trunions! No wonder it drove me nuts. Finally, I had to create them myself, as I used pieces of paper to "shim" the trunion/table interface for what I thought was poor machining tolerances from the factory. Glad that was the correct way to go about it.
Dave--- who remembers the hours spent cussing and fussing to get things right
