Yellow glue & danish oil
Barry Rubenstein
>I completed a project and the finish is danish oil, but now see that I have to glue one more thing. If I let the oil dry (a week ?), will the glue hold ?
Barry Rubenstein
Probably not..
Mike in Paradise
>Depends on exactly what you are trying to do. Give us some more detail.
At a minimum you are going to have to sand the surface but the problem with oil is that it sinks into the wood.
I keep my work bench oiled so that I can easily pop off the glue spills.
Re: Probably not..
Barry Rubenstein
>I have to put little screw covers over countersunk screws; the covers will "span" over onto the wood about 1/8" all around. I guess I could use a 2 part epoxy; that would drip into the Phillip screw "cross" and add to the holding power.
Whaddya think of that ?
Bazooka Joe Bubble Gum..
Mike in Paradise
>Do they still make it?
Seriously that is a very low stress application. Most of the buttons that I have installed have a taper and pretty much friction fit reasonably well.
Epoxy will work but I would probably use a drop of silicon so I could easily scrape it out if at some point in the future if I needed to get back at the screws.
Re: Bazooka Joe Bubble Gum..
Barry Rubenstein
>Are you asking if 2 part epoxy is still made ? Walmart sells it in a double syringe arrangement; one side is hardener and the other is resin.
No..LOL
Mike in Paradise
>Not epoxy...Bazooka Job Bubble gum LOL
