Priming over shellac
Ken Miller
>I have a piece that was finished with shellac that was tinted with transtint. I now want to paint over it so I started to put on a coat of primer. However, the color from the tint is really bleeding through. Before I continue, I wanted to know if there is any problems with priming over shellac? Is this something that a second coat of primer will fix? Thanks in advance.
Re: Priming over shellac
shellac is a primer
Dustmaker Mike
>if I am not mistaken shellac is a primer and is used all the time to stop bleed though of other finishs. Now if it is a waxed scellac all bets are off. But I would feel safe to say you are doing it the right way.
Use BIN
Michael Dresdner
>BIN is a bleed stopping primer. While the dye might bleed into the BIN, it will not bleed through and above it into the paint coat, assuming the paint is either water or oil based, so if you do get discolored BIN, don't worry about it.
