THE WOODRAT IS BACK!
Panel Saw Sale *LINK*
Brad Thompson - Hartselle AL
>No affiliation what so ever. Just received one of those mailers with mail back cards and one caught my eye. A vertical panel saw with saw for $599 during the month of march.
I've always wanted one of these for cutting sheet goods. Even with a big outfeed table and roller stands I find cutting 3/4" ply and mdf a challenge on the table saw. These have always been outside my budget but this one is within reason.
Anyone else have one or see the value?
Thanks
Brad
http://www.panelpro.com
Re: Panel Saw Sale *LINK*
Re: Panel Saw Sale
Carol from AZ
>I once had a panel saw in my shop. I see a functional problem with what is offered. Look at the amount of support for the sheet on either side of the saw blade. Even if you restricted this saw to cut an 8' sheet in half, the resulting 4' is not adequately supported. While it might balance there while it was 8' long, the 4' pieces wouldn't!
Do they had a 'fix' for this? Probably. Better figure it into the total cost of using this thing. Then after you have the extension supports, where do you store the darn thing? I found that I needed 10' of total support. That's a minimum of 3' on one side and 7' on the other or 5' on either side. You might get by with 8' total, but that still is bear to store. Think about cross cutting a foot off an 8' piece. How is the remaining 7' supported?
Just something to thing about. Hope I haven't rained on your parade.
Re: Panel Saw Sale
Robin Corell in Atacsadero CA
>I've worked at a couple of shops with panel saws and they all had large outfeed/ infeed areas. the better ones also have fold out supports so you can cross cut a 2' 8' strip without sitting on the floor and rollers to help slide goods along the infeed/outfeed/ without exception these saws all cost more than the avererage cabinet saw. they are handy and acurate and earn their keep in a shop that orders sheet goods by the unit. in a small shop it would be hard to justify such a saw. I would have reservatins about a set up like the one in your link. what Carol said is spot on. If you have your heart set on a panel saw I would recomend looking for one with more features on the used market for a similar price.
Robin Corell
albertabob
>Brad
I would think you could make one with similar features and a few improvements for a good deal less than the one you are looking at.
It is a back burner project of mine for when I build my shop later this year.
I am currently looking at a fairly decent plan in ShopNotes for my shop.
The carriage that holds the circular saw travels on a pair or rails (10 feet long) to either end of the bed allowing one guy/gal to load the sheet stock directly.
I dont have the issue in front of me as It is on my desk at work but you should be able to google it. (shopNotes)
Bob
Shopenotes panelsaw video
That would buy a lot of 2" foam
Charles Sharp
>I use a piece of 2" insulation foam on the floor with a straight edge and a circular saw to break down sheet goods to a size I can handle.
Re: Panel Saw Sale
Mar kBrennan
>I built the one from Shop Notes. Total Cost under $100, using stuff from shop as material.
It works great and save a lot of time.
Re: Panel Saw Sale
>Mark,
Any chance of some photos? Maybe some details on the building experience.
I'm not sold on the one I posted about, so no rain on my parade.
Thanks,
Brad
Re: Panel Saw Sale
Mar kBrennan
>Will take some this weekend and post them
