>I just mounted and exercised a Lenox Tri-Master 1/2" carbide tipped blade on my old Delta, and what a treat it is. It glides through pine or hard oak with equal ease, and makes the 3/4HP motor think it's on steroids. I'll be creating opportunities to do resawing. Bookmatching, here I come!
>I ordered it from toolcenter.com at $105. The saw is over 20 years old, 3/4 hp motor, original tires and spring, no riser, aftermarket cool blocks. Blade doesn't seem to need much tension. Don't know if it can be resharpened.
Your experience parallels mine. I liked my Lenox Tri-Master so much that when it broke at the weld (following very heavy use resawing 4-10 inch jatoba), I immediately bought another as I didn't want to be without it. Though expensive, it is money well spent IMHO. Even in my modest setup, there was virtually no drift and the saw marks could easily be removed by a light pass through the planer.
I also use the blade, have a 14 inch Delta with riser, an aftermarket spring, and the original tires. No problems with that setup. As far as I know, the blade cannot be resharpened. And, supposedly due to the smaller radius of the 14 inch bandsaws wheels, there have been reports of premature fatigue failure of the weld; maybe the welds are better now. Although your question was directed to Clint, I hope this helps a bit.
>On both my bandsaws, I have carbide-tipped blades, though I keep a regular Timberwolf on my smaller saw most of the time because I'm always cutting up firewood and roughing bolw blanks with that saw and I don't want to hit stones or metal. But, for long life and clean cutting, you can't beat carbide. And the variable pitch tooth configuration virtually cancels out the vibration and resonance you get with equally pitched teeth.
At one point, I did the math and figured out that if a carbide blade lasts 20 - 40 times as long as a regular blade, that makes them less than half the cost of a regular blade, plus they're resharpenable, or at least so I was told by Lenox when I did a blade-comparison sidebar about 10 years ago.
