Glass panel cabinet doors
Tom Meikle
>I just had a couple ask me if I could make them some new wall cabinet doors with glass panels. My questions is if anyone knows of a source of instructions on how to install the glass. I've made many raised and flat panel doors.But,this will be my first with glass
Re: Glass panel cabinet doors
mdclor
>Tom,
I can't answer your question, but price some commercial cabinets with glass before you set a price for yours. LOML was looking at some and the glass cost about an additional $500/cabinet. Suddenly, my tools looked a lot more reasonably priced.
Merle
It's easy
Clay Foster
>I made cabinets for our kitchen with stained glass panels my wife made. The glass is held in the frame in rabbets with wood stops. Drill undersized holes through the stop and into the frame, redrill the holes in the stop the same size as wire brads, and carefully hammer in the little brads. The stops are about 1/4" square. A good undersize drill bit for 16 gauge wire brads is #56.
These doors have a sunrise in them. Some other doors have a moon. Countertop is pecan.
Jim Dillon
>Tom,
Just about any monthly woodworking mag usually has at least one plan for some type of cabinet with glass in the doors. You might find something helpful there.
Basically, it is straightforward. One method (probably the most common) assembles the stiles and rails for the door, then cuts a rabbit in the backside of the door - using a router - deep enough for the glass and a small piece of wood to hold the glass in place. The corners or the rabbit must be squared off with a chisel. The small piece of wood used for the retainer can be roughly square, or molded - depending on the style of the furniture piece. It can be brad nailed in place, or attached with small nails.
Another method, and one that I like, is to use off-set tenons for holding the stiles and rails together. This process generates a matching strip of wood that is then used to retain the glass. If you keep track of the pieces, they will match perfectly with the inside of the door. To hold them in place, I predrill small holes for brass escutcheon nails (Lee Valley) and gently pound the nails in. I think they look quite nice. One description of this approach is in FWW #128 Jan/Feb 1998 in an article by C. Becksvoort on building a bookcase with glass doors. Hope this helps.
Jim
I just checked FWW...
Jim Dillon
>... and that issue of FWW is no longer in print. However, that same article is in a FWW paperback called In the Shaker Style, pages 66-73. I've seen this paperback in my local book store from time-to-time. Sorry for the misleading statement.
Jim
