Re: Can One of You LINUX Guys Point Me . . .
wilbur
>Hi Rob,
The most foolproof way to mess around with Linux is to use Knoppix, which is a Live CD distribution. What this means is that you drop the Knoppix CD into your optical drive, and boot off of that. It will magically figure out all your hardware and read your drives, and boot up. It's going to be slower than running it off of a dual boot system since it runs off of a CD, but it will give you an idea as to what running Linux will be like.
Basically, if you are trying to install Linux on a computer already running Windows, whichever Linux distribution you use, the steps are more or less the same:
1. Create a partition that you can run Linux off of. This is the hairiest, most nail biting part. You will be using a program like parted, GParted, Partition Magic, or something similar.
2. Install Linux onto the new partition.
3. Depending on the distribution, you may have to muck around with the MBR.
The safest thing to do is to get your hands on an extra hard drive, and install Linux on that. Linux should be able to read your Win XP hard drive.
There's a lot of information on how to set up a dual boot Win XP/Ubuntu system. Here are some links:
http://www.hezardastan.org/breezy_xp_dualboot/en/
http://www.matthewjmiller.net/howtos/dual-boot-linux-and-windows/
There's even a video guide:
http://video.google.com/videoplay?docid=-6104490811311898236
And, of course, there s the Ubuntu forums:
http://www.ubuntuforums.org/index.php
For running Linux, Google is not just your friend, it's your lover.
I promise, you will be able to do this. I did it back in 2002, when it was much harder. I use Gentoo, which is a compile from source Linux distribution, and I'm not even an IT person. Ubuntu is much easier to get running.
