Delta 22-580 planer
Dave Winters
>Suddenly my 22-580 planer doesn't feed very well. It's like it feeds about 8"worth and stalls, till you push again, and then same deal..
Anybody have similar experience?
Thanks,
Dave
Delta 22-580 planer
Dave Winters
Thanks,
Dave
Re: Delta 22-580 planer
Dave Bair, Eaton Rapids, MI
>Clean the rollers (I use spirits) and wax the bed. Also, it's a good time to see if the knives need to be replaced or rotated.
Dave Winters
>Yeah, thanks. I did that, didn't seem to help, it really seems to be something with the feed mechanism itself....
In that case, there is a belt ...
Paul Dwight
>My advice would have been the same as Dave's, but since you've already tried those measures without fixing the problem, you might want to check the belt that drives the feed rollers. The one that broke on me failed all at once, but it might be possible that yours has a partial tear that lets it slip intermittently. As I recall, the part is about $15 and installing it myself was no big deal.
Good luck! -- Paul
Alan Tolchinsky
>This is probably too basic so please forgive me if it is: But is your speed control set properly? I have to give mine a good solid push into the speed I want while the machine is on but no wood is going throug it. O.K. I knew you knew this. :)
