Kickback followup
Mark in B'ham
>As a follow up to my previous thread Kickback - Ouch I have put together a list of Rules of Thumb (to keep your thumbs on your hand) when setting up cuts on the tablesaw. I thought I would post them here for any corrections, annotations, and additions.
- Keep the workpiece as big as you can as long as you can. This usually means rip a board to width first then crosscut to length.
- Don�t try to use the fence for pieces that are too short. The piece should pass the blade reach the splitter once it is cut. As Lee Schierer said �The safety rule here is the length of the piece along the fence should always be 1-1/2 to 2 times the width between the fence and the blade.�
- Use the miter gauge or a crosscut sled for crosscut operations. A block can be clamped to the fence to use to keep things the same length, but the block should end before the blade to keep pieces from being trapped between the blade and the fence.
- Using feather boards with small pieces can be dangerous as well. As Jim Dillon notes, the piece may try to rotate when it disengages the feather board and contact the blade. Don�t place a feather board where it will push a piece directly toward to blade (i.e. right beside the blade).
- Stop and consider if the table saw is the best way to get the cut done. Smaller pieces can be more safely handled on the bandsaw. A handsaw and a miterbox might be the best solution if there are only a few cuts.
- Most important of all is to think through the cut before turning on the saw.
I hope these are helpful.
Mark
Just trying to keep all my fingers
