Re: finishing question
NickB
>You can use shellac, just use 2, maybe three coats (more if you are wiping on). Shellac doesn't start to get shiny until you've built enough of a coat. Dries fast, non-stinky, and can be recoated in a snap (can also be reduced/removed with alcohol). I really like unstained cherry with blond shellac (Zinsser SealCoat is great-if you use the regular canned shellac, check the date on the can to be sure it is fresh). If you do use shellac, avoid using any alkaline cleaners (e.g., ammonia-based), as shellac is very susceptible to alkaline attack.
To quote (roughly, but I'm pretty sure this is right) Michael Dresdner, "fantastic finishers frequently finish firewood." In other words, whatever you're thinking of, try it on some scrap (like some offcuts from your project) and show them to your client (wife).
Hope this helps,
Nick
