OT printer problems
OT printer problems
OT printer problems
Ernie miller Topeka ks
>I have an ink jet printer and don't print very often. it is full of ink but dosent want to print. I think the ink has dried up in some part of it is it possable to clean it and how where do I clean and with what?
Re: OT printer problems
Robert Hutchins
>Hey Ernie!
You can buy a head cleaner kit for ink jet printers, I think; but if the ink has dried too much to flow thru the tiny nozzles, it's not going to do much good. If you have printer that you don't use very often, you might consider removing the cartridge and packing it in a zip lock bag very tightly sealed - maybe with a damp paper towel in it - and install it only when you need to print something. I keep spare print cartridges on hand and they sometimes dry out before I ever open them.
HTH
Re: Most printer have a nozzle cleaning...
Jamie Donaldson
>....utility bundled with the operating system, but the only sure cure is to use it regularly.
Jim Dillon
>Ernie,
You didn't say what brand of printer you have. HP's cartridges usually come with their own printer head built into the cartridge and that is replaced each time you need a new cartridge. Canons and Epsons heads are separate and, in theory, can be cleaned if the normal built-in cleaning procedure doesn't work. Some people have luck with a warm water soak, the use of a water/Windex soak, or the use of a 10% clorox/water mixture. I've used the warm running water method and have been amazed at the HUGE amount of ink that can be trapped in the print head. I believe the recommended practice for Epson printers is to turn them OFF when done as the nozzels are then capped to prevent drying. All of this is more art than science so good luck.
Jim
Lemme guess...
Denis Ch�nard, Orl�ans, Ont.
>Is the printer an Epson?
I had two of those, and they're fine, but if you don't use them regularly the ink clogs up the heads and then the printer won't work correctly.
I owned two Epsons, and they both did the same thing. Switched to HP and never looked back. Epson has the printing head as part of the printer, can't replace it. HP has the print head as part of the cartridge, so if the head clogs, a new cartridge fixes things.
Still, I have yet to have a clogged head problem with my HP printer, even though we don't use it that often...
DC
For no more clogs -- switch to laser
Lee Schierer - McKean, PA
>I had an Epson and it clogged because we didn't print very much. I tried cleaning it and it would work for a bit then quit again. Cleaning was pretty messy too. I've seen similar problems with HP printers though an new cartridge solves the problem you throw out most of the ink in the old one.
My final solution was to buy a laser printer. The Brother HL 2040 is inexpensive and does a superior job printing. It doesn't care how often you print and it is fast. If we need a color print, I take a disk to one of the office supply places and they print it for a nominal charge (much cheaper than color ink).
Ernie Miller
>it's a lexmark does the head just pop off? I guess at this point it's not like I can ruin it is it? I still need the scaner for it but I can get by if I have to buy another one. I would like to clean this one if possable.
Model specific?
Bill Howatt
>I have an Epson 740 which is quite old and it only gets used occasionally to print photos. I use a HP Laserjet for everything other than photos. The Epson has never clogged although I make sure it is shut-off when not in use as recommended. It moves the cartridges into an area where they are "sealed".
If it weren't for photos, I'd only have a laser - the cost per page is a lot cheaper and laser printers are now very affordable.
BIll
Re: Model specific?
>You raised a point I had forgotten. I've had a 400 and a 640, and I did leave them on all the time as they were connected to my router. I didn't want to have to go upstairs to turn the thing on when I was working downstairs on my other computer. So that probably didn't help with the clogs, although I did turn off the 400 before I got my router, and clogs were still there although less frequent.
But since I replaced the 640 by a HP 5650 I've never had the heads clog on me, and that printer stays on all the time.
DC
Ray SW Ohio
>You can try cleaning it but you will probably end up buying a new printer. I had a Brother Intellifax and it used a lot of ink just "cleaning" itself, it ended up being clogged anyway. Had 3 Lexmarks that ended up in the trash after clogging, print heads were too expensive. Now have 3 Canon inkjets and one Canon laser. Never had a problem with them, one is 5 yrs old too. The print head is going to cost more than a new printer. Buy a new printer, cleaning usually does not work. My 2�.
