Bearings in old Americnan iron vs import iron *LINK*
Phil Smith
>Found this article over on OWWM.org comparing the bearing sizes of old American woodworking machines vs new imported machines. Thought some might find it interesting.
Bearings
Phil Smith
Bearings
Nothing new, they have been doing it
Ray Thompson - Middletown,IN
>for years. Back when we made Alternators ours were built for "x" number of hours of run time using ball bearings. The "rim" competion were made with bronze bearings and made to be replaced soon after warranty expiration, opening up the replacement parts market sooner. Were ours over engineered or were they better at profit and marketing? Me thinks me knows the answer.
Ray
Re: Reality versus over built...
Rick L
>Instead of looking at it being cheapened I think the old iron was way over built. For instance the Unisaw has three belts on it. PM used to as well and went down to 2 belts. If you look at the Euro sliders with 9 hp motors they are running 1 small belt. I've seen these belts last amny years and when the do go they are relatively inexpensive. The Unisaw can get by wuth one belt but if they reduced it to one belt the non-engineer background consumers would be screaming "CHEAPENING and INFERIOR PRODUCT"!!!!!
Euro machines have been using concrete to dampen vibrations with plate steel construction versus cast iron. If the modern plate and concrete versus cast iron does the job who cares. People don't realize that with the tiawan imports there are more machines available for the hobbyist and small shop than were availble 30 years ago and they are prices pretty close to what they were over 20 years and the quality is getting better every year...tomorrows old iron!!!! Ever see the pictures of the shops in South America with an arbor mounted under a sheet of plywood for the only power tool in the shop...folks in the states have it more than good and still you hear people splitting hairs about even Harbor Freight being expensive. Many parts of the world can't even afford Harbor Freight.
