To Glue or Not To Glue (Part 2)
Murph
>To Glue or Not To Glue (Part 2)..that is my question...
I�m building an entertainment center (see below) that will have cubbies or shelves within the bottom case. All of the construction is of solid Cherry with the exception of the outside case which is cherry plywood. Partitions A will be secured to the top and bottom frames using screws and allowing for expansion front to back. Partitions B C and D I would like to make fixed or secure as well but I�m challenged on how to do it and still have the structural strength I need for the top case that will fit on this bottom case. I�ve thought of using bisquits, or dados with securing just the front of the partitions (to allow for movement to the rear), but again worry about the structural integrity if I�m only securing the partitions at the front. I�m reluctant to screw B & C as this would ascetically not be too nice. Any help would be appreciated. )PS - New to Sketchup.
Thanks
