Ottoman chronicle - in the shop with LOML *PICS*
Tim Greif - West of Chicago
>It's not very often I get to share shop time with LOML, but this is a good example of us working as a team , each doing what we know best to make a new and useful item. We decided to venture into upholstered furniture. Now we've already re-upholstered an old rocker. So we kinda sorta had some prior experience, but only on re-doing something we could make a pattern from. This time, we decided to actually make an ottoman for the family room from scratch. I got to do the tool and wood stuff. LOML got to use her sewing talents, which are pretty impressive in my mind.
The sequence below shows the project. We worked well together and had fun doing it. She had no desire to build a box or use the stapler, and I had no interest in sewing. And it turned out pretty good. So get your sweetie in the shop and make something together. I highly recommend it.
Just so this qualifies as a woodworking or tool post, the first picture show the tool we used for this and the prior upholsetery jobs. It's a 22-ga. fine wire upholstery stapler, fires 3/8" crown staples up to 5/8" length. I found this tool on sale at Amazon for $40 but it normally goes for around $70. Does a great job and is much better for this kind of thing than the 18-ga. 1/4" crown staplers you normally see. These staples can be removed easily for repair and re-upholstery without damaging the wood. And yes, I did need to remove some to do some repositioning and fix one or two of my "not quite right" attachments.
The next couple pics show the box construction and the 3" seat foam and batting application. You need the batting or dacron or jute to give the final fabric something to slide against instead of just the wood or foam surface. At least that's what LOML tells me. And I ALWAYS listen to what she tells me, right?
These next three pics show the fabric application. My knowledge of sewing is about as vast as my knowledge of nuclear physics. All I know is Maryanne made the cover in three sections - top, middle panel and bottom pleated skirt. Each panel was separated by fabric covered welting, the round cord type piping thingy piece of material. She sewed each piece so it fit snugly on the box and I stapled everything in place. How she was able to sew all this stuff together to fit so well is a complete mystery to me.
The welting needs some support beneath it to give it a straight line edge. You can't really just use staples to do that. You need a strip of cardboard tucked just beneath the welting and stapled in place. For that, I cut some strips of cardboard from a diet budweiser container. The pics show how it's stapled beneath the welting to establish the striaght line.
And here's the finished product, ready for use. Now for a woodworking or furniture upholstery project, the difficulty factor of this little gem is probably the equivalent of building a birdhouse. But we had fun and we like it. And thanks for looking.
Re: Ottoman chronicle - in the shop with LOML *PICS*
Great post, Tim
>This could easily be an article. Thanks for posting. Nice job on the ottoman, and I'm impressed that you and your wife collaborated on it.
Mark McC
>Nice work. Bud Light institute would be proud!
Great Team Effort, Tim!
Robert Hutchins
>But I think she gets extra kudos 'cause all her work shows :>)
I agree with Ellis. I betcha David grabs this one quick and asks you for more info for a shop shot or maybe Garrett will get to you fist for an article.
BobH, stirring the pot!
She should be posting this!
>Tim,
Who was the "sub-contractor" here? Looks like YOU were! Nice of you to help her with HER project! ;-) And kudos to her for such great work too! ;-)
Just kidding there. Nice job to both of you. Nothing beats a comfy place to prop up a pair of tired dogs.
Tom
Great job and post, BUT
Joanne Adler in Pt. Pleasant, PA
>That shop is way too clean for ONE person working. For TWO people working in it, it is absurdly clean! ;-) Kudos to you both on a super project that you'll get to enjoy and show off daily.
Indeed! Thanks Tim!
Mike Farinella
No Competition here at WC
Garrett in Victoria BC
>This is, after all, a friendly place. (But I did capture the post immediately. Unfortunately for me, David is usually much faster at getting it published.)
Cheers, Garrett
No Chance....
David Yoho
>Time is so tight for me right now I can't even get to the work I have waiting. I'm glad to see it will be added to the Articles section as there's little chance of me getting to it before several more weeks pass. I've got a mega shop shot to edit first and can't even tell just how soon that will happen!
Thanks for picking this project up and running with it.
David - (seems like the hurrieder I go, the behinder I get!)
