ebonized wood
John Kusanovich
>I need help to darken wood for seg- turnig spacers.spacers are .025 thick.
Thanks for any information
JK
ebonized wood
John Kusanovich
JK
Re: ebonized wood
Lee Ohmart
>I have used India ink and it looked good. On another project I used a Ferrous sulfate wash on a species of wood with a high tannate content (walnut) and that was effecive as well.
Re: ebonized wood
John McGaw
>The black dye used by leather workers has done well for me over the years. It is rather cheap and easy to apply.
Re: ebonized wood
Mark Kauder, Phenix City, AL
>John,
How thick are your spacers.
The problem with dyeing, staining, or ebonizing wood is that there is a limit to how deep the solution will stain the wood. If you are talking in the 1/16" to 1/8" range,you will probably be OK.
I just buy black (dyed) veneer.
Mark
Re: ebonized wood
Stuart Johnson
>I soak Walnut veneer in a vinegar/steel wool mixture. Turns it very black and goes all the way through.
I wonder...
Dan Donaldson
>Do you think it would work to cover a piece of wood with a liquid dye and then pull a vacuum on it to draw the dye through the piece? It would seem that the vacuum would pull at least some of the air out of the piece of wood and when the vacuum is released, the dye would replace the air. Just a thought.
Re: I wonder...
Carol from AZ
>If the piece were submerged in a container than could survive the vacuum, that might work. To just apply it, I'd think you would get very uneven results. Not to mention messing up your bag really bad.
When we did the get the bubbles out of polyurethane or epoxy, it took only seconds, and we had a thick plastic container where we could watch the results. I was particularly interested to see if the liquid would be evacuated by the vacuum pump after the air was out, as I was not eager to pull polywhatever into my pump! I never left the pump on long enough to find out!
In the case of dye into wood, when do you shut the pump off?
Re: I wonder...
Dan Donaldson
>I wouldn't use a bag, but rather some kind of container. They make some that are a solid container with a lid that has a hookup for a vacuum line that are used for some of those food processing vacuum systems. I was thinking more of submerging the part in liquid dye and pulling the vacuum then releasing it.
Re: I wonder...
Carol from AZ
>Let us know how it works. I'd also be interested in seeing the container you are talking about.
How it is done
Michael Dresdner
>You've come perilously close to guessing the way vacuum dye jobs are actually done. Typically, the wood is placed in a vessel and a vacuum drawn. That pulls most of the air out of the wood itself. Dye is then introducted to the vessel so that the vacuum pulls it into the pores of the wood which are already devoid of air. In other words, the dye is used as an air replacement.
