Question on alcohol and heart pine discoloration.
>I am building a huntboard out of quartersawn heart pine. I used Denatured Alcohol to clean epoxy off a joint. (The timbers I resawed for this were salvaged and I cut into an old fastener hole with one of the mortises. Decided to use epoxy to compensate for the missing material.)
Now I have a reddish smear where apparently the alcohol floated out some of the color of the pine. Now what do I do? Wipe down the whole piece?
Re: Question on alcohol and heart pine discoloration.
John in Kerrville
>It sounds like you picked up some of the pine resin. Do you have some scraps to play around with? If so try a little acetone to see what that will do.
Forgot to
John in Kerrville
>suggest turpentine also.
Sand it down
>Any color that leached out will probably be only a couple cells deep. You should be able to restore the natural color with some light sanding.
Rats, I was affraid...
>you were going to say that. I had very carefully sanded this thing before I assembled it. To make matters worse, I even wiped joints that did not have epoxy in them, with the DNA, "just to be sure" I cleaned up any squeeze out.
