>I have made a wood frame of Ash to frame a large wall mounted mirror and have a need to glue a portion of the wood frame to the glass mirror. I think contact cement will work but I was wondering if anybody has a recommendation for a good east to find glue?
>Do not use contact cement for any thing that will have any pressure on the mating pieces.
For small mirrors I sometimes use silicone on the back side of the mirror to the frame. For large mirrors I prefer to find other ways to secure the mirror into the frame like dados or plywood backing. The mirror will expand and contract more than the wood with changes in temperature, and the wood will expand and contract more with changes in humidity.
>The professionals use a silicone based glue that you can get from your local glass store. I have found that clear silicone caulk looks, smells,feels, and probably tastes the same and is less expensive. I make hand mirrors and have glued in hundreds. I haven't had any failures with the clear silcone.
I originally tried liquid nails, contact cement and F26 glue. Liquid nails failed miserably, the glue stuck to the mirror but popped off the wood. The Contact cement will degrade the mirror coating. F26 worked well on 4" mirrors but didn't allow enough wood movement on larger mirrors.
>You might contact your local auto glass shop. 3M has a product which will glue plastic to glass, wood and anything else. I have used it in the past with not problems, however, it is messy to work with, and will require, acetone or lac. thinner to clean up.
