Veritas - Innovation in Tools
hvlp question
hvlp question
hvlp question
stevo wis
>Hope this doesnt sound too dumb, but I cant seem to find an answer.
I have a hvlp accuspray conversion gun that I have set per the instructions and have had good results with it.
It sprays very similarly to other air guns and puts out a fair amount of finish, and as such needs a fair amount of masking for overspray etc.
My question is this: I have seen one demo and another on tv showing a turbine hvlp, which is barely dribbling out paint. It is very low pressure and takes quite a while to paint. Since it is so little coming out, very little masking is needed and it could easily be used to paint a installed door etc.
Should my conversion gun act like the turbine or more like a conventional gun? Im not sure if I am setting it right even though I get good results. I would like to cut down masking if possible and want to learn to do this right in any case.
Any advice would be much appreciated.
thanks,
Stevo
Re: hvlp question
Re: hvlp question
Ed Mulligan, Cape Cod
>Stevo -
I have an Accuspray turbine setup. It runs at 6 psi. Your Accuspray conversion gun requires around 40 psi so you will have much more 'blowback' than a 6 psi setup. If you are getting good results it sounds like it's working ok.
Ed
Re: hvlp question
Re: hvlp question
John Parker
>HVLP guns are required to have no more than 10 PSI at the tip outlet. You can turn up the inlet air to override this. Make sure you are not setting the inlet pressure too high. You do not need to set the inlet pressure as high as the MFG recomends. Try turning down the inlet pressure and check for good atomization. You can go down with the pressure until you stop getting a good pattern.
Re: hvlp question
are you sure of this statement?
bill tindal, E.TN
>While the primary pressure in the air line to gun may be 40 psi the internal pressure is dropped through expansion to that of a turbine. The 40 psi is to get enough air to the gun to run it. There should be no difference in the atomized spray coming from the gun which ever air source is used.
If there is too much over spray or too much finish being delivered then something is not adjusted right. Consult the manual or tech service at the manufacturer.
Re: hvlp question
Re: are you sure of this statement?
>bill -
I don't know the science behind it but generally speaking lower pressure equals less overspray and blowback.
http://www.advancedfinishing.com/sprayguns.html
Ed
Re: hvlp question
agree with data; I think conclusion is incorrect
bill tindal, E.TN
>As I understand the operation of the conversion guns, which I own one of, air is delivered to the gun at 40 psi with some flow and then inside the gun the pressure and flow is converted to that which the turbine would have delivered (that would be lower pressure and higher flow volume, PV will be a constant). If not, then what would be the purpose of the "conversion gun"? Mine has vastly less over-spray than my DeVelbiss gun. I was told when I bought it that it would save 30-50% of the material I sprayed because of reduced over-spray. I have seen no reason to dispute this claim.
On the other hand I quit using the conversion gun. It is great for the insides of things. Because of the gentle flow from the tip, spray doesn't blow around everywhere and it coats inside corners nicely. But, it is much more picky to adjust for uniform and well-atomized delivery to flat surfaces. No doubt more experience on my part could solve this problem. It became a purchase I wish I had not made.
Re: hvlp question
oops!
>bill -
I didn't know that the psi at the gun tip was low - less than 40. Thanks for the info. I found a Binks website that described the tip psi could be varied from 3 to 10 psi.
I've never used a conventional gun. I've spent many hours with a Binks HVLP conversion gun with 30 psi to the gun. When I switched to the Accuspray turbine (6 psi) I noticed a sharp decrease in material used. It must be the Binks was adjusted near the 10 psi upper limit.
If the original poster is still with us, please ignore what I wrote. I am sorry for the confusion.
Ed
Re: hvlp question
Re: agree with data; I think conclusion is incorre
del schisler
>i have a HVLP that i have used for probly 4 yrs With 40lbs of air I spray lacquer It work's for me You must have the right tip to get it to work right Mine with lacquer cleaner in the gun NO AIR HOOK TO GUN pull the trigger the streem should go out 6" This is what i am told than the tip is right I belive 1mm I drilled mine out to make it work right
Re: hvlp question
Clarification, and some gossip
Michael Dresdner
>First, go back and read John Parker's entry. It is entirely correct.
Now let's explain just a bit more. Throughout most of the country and for most woodworkers, there are no laws concerning tip pressure. SCAQMD did in fact pass some local regulations applicable to Southern California about maximum tip pressures for HVLP, and that is the benchmark everyone uses, but again, most of us, including all hobby woodworkers, are not bound by law.
What Parker said is true -- if you put enough air pressure into a conversion gun you can get it above 10 psi at the tip, and he is also right to point out that too much air is simply a waste. You want only enough to atomize well.
What you WILL find is that some guns are more efficient than others. For example, the original Binks BBR conversion gun required 20 cfm at almost 80 psi to produce a good atomization at 10 psi at the tip. Over the years gun technology has improved. Accuspray in particular seems to get extraordinary atomization with very low pressures and very little volume, usually below 40 psi and 7 cfm or less. So, yes, things are different than they were several years ago, and yes, some guns require more air to do the same job than do others.
Does that help?
Here's a freebie, in case you did not hear it through the grapevine: On Feb. 1st, 3M announced it had purchased Accuspray outright. Look for some major changes. Want to find out what? Read the piece on Accuspray and 3M coming out next Tuesday in the Woodworker's Journal eZine. (It is free to subscribe to this magazine. No strings attached.)
Re: hvlp question
Re: hvlp question
NickB
>That's pretty much what I do. I have a Walcom STM conversion HVLP gun (small gun, due to my relatively small compressor). I set my compressor regulator for 40 psi, then, starting with a very low pressure setting on the regulator at the gun, turn up the regulator at the gun until I get good atomization. I won't pretend that I'm the best at spray finishing, but I have been getting pretty good results as of late (especially now that I've learned not to shoot wb finishes when it's too cold-talk about orange peel!).
Nick
