Door Fronts of Woven Wood
Howard G
>Here's what I plan - I ordered 1/16" thick cherry and walnut veneer from Certainly Wood(very nice guys). I will cut 1" strips and weave together in a basket weave and then mount to 1/4" plywood. Would you presoak the strips, or mist with water before weaving? I do not want it too wet and then have to wait too long for it to dry. Should the would be heated while damp? Appreciate your thoughts on this. I will be working on this this weekend. Thanks again.
Re: Door Fronts of Woven Wood
Issues to think about
>First, whether you have to soak or mist or otherwise make your strips more pliable depends on the thickness of the wood versus the severity of the bend. If you want the strips to be fairly tight together after you weave them (i.e., no major holes between the crosshatches), you'll probably have to soften them up somehow. Also, cherry is not a good bending wood, so this could be an adventure. For inspiration, I suggest you look up some articles on weaving a hickory bark seat.
I've made doors and dressing screens and such with woven wood, but sometimes I wanted something thicker than 1/16" for strength and stiffness. That would have been really difficult to weave, so I came up with an alternate design that was much easier to do. I mortised three vertical pieces of a contrasting wood into the door frame at intervals and then wove my strips perpendicular to these verticals. The result is woven only in the horizontal direction, but the effect is still pretty nice.
Ellis.
Woodenfish
>I built a project that incorporated a woven cherry panel and didn't need to do any water soaking, misting or steaming to assemble. The dimension of the cherry strips were 1/16" x 3/4" so it was quite similar to your design. The closest I could get the verticle pieces together was about 2-1/2" by carefully tapping the strips together with a hammer and a scrap strip of pine. The finished pattern looks like a 3/4" square followed by a 5" strip.
Having the wood dry helped minimize the thin grain from compressing. I think that yours being a little wider will enlarge the weave a little more. You might consider cutting the strips more on the narrow side if you are looking for a tighter weave pattern.
Keith Newton
>Howard, From what you have described, I would have been tempted to start with green lumber, and ripped thin strips off, and have woven that. It would be more limber to begin with, cheap, and 1/16" would dry very fast.
If you are into vacuum bagging, and if it came out lumpy, I would consider putting it between cauls/sheets of mdf, with the top side painted black, and put it out in the sun under vacuum, to generate some heat. That ought to dry it out, and smooch it all together flat, and tight.
Commercial sighting
Ed Mulligan, Cape Cod
>I have a (purchased) laundry hamper with a similar arrangement to what Ellis describes. The non-woven verticals are ~ 1 1/8". The horizontals are ~ 1 3/8". Thickness is ~ 1/16". Looks nice.
Ed
