To glue or not to glue
Lee Schierer - McKean, PA
>I'm making a dresser with a bead board panel side. There will be eight 2" wide tongue and groove strips of bead board that make up the panel. They will be confined on the edges in a groove in teh frame. The panel will be 16" wide and about 30" tall. The question is should I glue these strips together to make a single panel or am I better off leaving them as separate strips. The wood is poplar and the panel will eventually be painted a solid color.
Lee
Re: To glue or not to glue
Hal Smith
>I wold not recommend to glue them. Have done similar panels and left them unglued. Hal
>Pre paint the individual boards, including the tongues and grooves. Join them loosely enough to accommodate any expansion. and pin each board at the middle into the groove.
Clint
I'd glue them
Rob Sandow
>Paint plus seasonal movement of each piece will quickly equate to the paint coming off at the joints between the bead boards. Pre-paint the panel and make the groove a little wider than needed, then add a liberal coat of wax to the groove before assembly to make sure the paint stays put.
