Workbench advice needed.
Tom Pilsbury (Chicago)
>I'm building a small workbench for my basement shop from 2X4s and an old door for a top. What do I do about the end grain of the legs sitting on the concrete floor? I'm afraid this will cause warping. If I apply a finish I'm thinking it will cause the bench to slide on the floor. Advice?
Re: Workbench advice needed.
Warren Muse, VA
>Tom,
When I build my bench, I went to kmart and bought a small polyethelyne cutting board. Cut 2-by squares on the band saw and attached to the legs with counter-sunk screws.
The plastic makes it possible to slide the bench around on a concrete floor. My bench is pretty heavy, so it stays in place while in use.
Hope this helps...
W
not something I would worry about
bill tindal, E.TN
Brian in SLO
>Unless you plan on standing in a puddle every time you work I wouldn't worry about it. And if you are standing in a puddle every time you work, you may have a bigger problem to worry about than the workbench legs.
Robert R Clough - Thorncraft
>A final note, if you are really worried, what about locking casters? They will get you off the floor and make it easier to move the bench.
Jim Dillon
>Tom,
Sounds like you are making a very functional workbench with a nice flat top. I've used one of those cheap, lightweight doors for an assembly table and it worked great. Personally, I wouldn't worry too much about putting a finish on it; it will get beat up over time plus finish/paint spills will give it character. Maybe some pieces cut from an old bathtub/shower rubber mat (or something similar) under the legs will keep your bench from scooting across the floor. And, as someone said, if you are standing in water, you have other more important issues to deal with. Good luck.
Jim
