Wiring multiple fluorescent fixtures to one switch
wilbur
>Hopefully this will be an easy question. I'm about to hang 5 fluorescent fixtures in my workshop. They will all be controlled by a single one way switch. The wiring will be such that the layout will be power ---> lights ---> switch.
If this was only one fixture, it would be easy, as I've done that before. But I've never hooked up multiple fixtures to one switch. Can anyone point me to a diagram as to how I should do this, or is it just a matter of tying all the hot and neutral lines of the fixtures together to make one big virtual fixture?
Re: Wiring multiple fluorescent fixtures to one switch
Ronald
>You got it all black togather and all white togather and on the switch end black on one side and white on the other.
Randy Johnson Connersville, IN
>You can use the light fixture as a juction box and simply tie black to black, white to white, and bare to bare. You should leave a long tail on the bare wire to allow grounding to the fixture.
That's the short easy answer.
The trouble, is that fluorescent fixtures come in lots of different flavors.
Most of the ones I have in my shop are the ten buck, one ballast, two tube, cheapies from the local home center. If there is an amperage rating on the ballast I couldn't find it so I plugged one into the convenience outlet on the panel and tonged the wire in the panel. Even when the meter was set at six amps I couldn't get a reading and I have six of these on one twenty amp circuit with no worries.
On the other hand, if I had used some of the older four tube, two ballast lay-in types there could have been trouble. I have been away from this for a few years, but as I remember it, those old 40W ballasts pulled about 1.95 amps. With two of these in each fixture, five fixtures would be for all practical purposes a full load.
Part of the answer to your question is another question. How much does each fixture pull?
Keith Newton
>Ronald, I am not too sure what you mean at the switch, but it sounds like a direct short to me.
If it is a single pole switch, the black Hot, goes into the switch, and the black to the fixtures goes under the other, the whites tie together with wire-nuts, also the grounds.
At each junction box for the fixtures, tie all blacks together, all whites together, and all of the grounds together. This is called a parallel circuit.
Different wiring setup.
Jason Roehl in Mulberry, IN
>He's talking about running the power to the lights first, then to a switch leg. In that case, he would tie all the blacks together from the lights, as well as the whites and grounds, but where the hot black enters the first fixture, that would get tied to the black of the switch leg, that runs to the switch, then the white from that same piece of Romex is on the other side of the switch and runs back to the fixture to be tied to the blacks of the fixture. Some places require you to indicate this setup by banding both ends of the white wire with black tape. If it's in conduit, one could just use all black wire, but with Romex, it's cheaper to do it the above way (only one run of Romex for the switch leg). I prefer to run the power into the switch box, then up to the fixture. (With the switch off, then there should be no power in the fixture anywhere).
Jason
Two Methods
Rick Christopherson
>If you have your power entering the circuit at one light fixture, and your switch connected at the other end of the run, then you need to use 3 conductor (14/3 romex for example) between each of the five lights. The extra conductor carries the hot down to the switch, and the return hot from the switch goes back to each light. (all neutrals are tied together).
If you didn't want to use the 14/3 romex, then you need to have your switch connected at the same fixture as the incoming power.
Dave W.
>As Rick mentioned, I would use a combo of 14/3 and 14/2 to make this connection. Attached is a diagram I did to show this connection.
Dave.
Option three, entirely different
Michael Dresdner
>After wiring five shops with flourescent lights, I came up with a method that saves me a bundle in time and aggravation, and it is in my current shop. Instead of hard wiring the lights, I simply run conduit along the ceiling with junction boxes fronted with outlets. Each light fixture gets a plug, which plugs into the nearest outlet. The cords are held up to the conduit via nylon ties.
Whenever a light fixture goes south, which they do with surprising regularity, all I need do is unplug it, unhook it from the ceiling, take it down and either fix it or replace it. Yes, it is more work up front, but it is so nice when you are right in the middle of something and need the light to be able to quickly switch it out, even if it means moving one from another part of the room until you have time to get to the hardeware store. These days I keep at least one spare light fixture in the shop at all times.
And yes, I have had times when I just happened to need that ceiling outlet for something else as well, and they all certainly come in handy when you are on a ladder drilling hangers to hang the lights.
Re: Option three, entirely different
Dave W.
>That is a good Idea Michael and it how I wired my shop lights in the basement. I simply put outlets in the ceiling that were controlled by a light switch. The diagram I did above would work with that scenario too. Simply replace the light fixtures with outlets.
Dave.
Dave LaPine
>We did the same thing also.It works great. We also added one fixture on a seperate circuit inside with a motion sensor so only the 1 light will come on automatically. It works great if you have your hands full or if someone needs to come in for just a minute to grab something. I don't like seeing the power meter spinning any more than neccesary.
Thanks! What I wound up doing (or plan to)
wilbur
>Thanks for all the replies. After staring at my basement wiring last night, I figured out that I could wire all the light fixtures in parallel with each other (black to black, and white to white), and I found a way to extend the wiring to the switch so that it would be in line before the fixtures and the power source, which seems to be the simplest method.
Jeff Mackay
Re: Thanks! What I wound up doing (or plan to)
Jeff Mackay
>In my first wiring disaster, I wired four flourescent lights with a single switch. The switch works great: it turns the last light on and off like a champ. The first three require me to turn off the circuit breaker. It's been almost five years now, and I still haven't gotten around to re-wiring...
Jeff
>Wilbur,
Your situation is simple if the switch is the first thing in line. You could do the outlets as suggested, but in either case, the wiring remains the same.
Your power feed is to the switch box. The black from the feed goes through the switch. Black into the switch and black out from the switch. The whites are attached to each other and so are the grounds, with wire nuts to maintain continuity, as if you had not cut them.
At each fixture, you attach black to black as if you were splicing the wire, but you include the power lead for the fixture. Same with the white. You attach ground to ground and add a short pigtail so you can ground the fixture.
At the last fixture, you just attach the black tot he power lead, but there is not third wire continuing on. Same for the white, and the ground lead just attaches tot eh metal of the fixture.
