Finishing help
Finishing help
Finishing help
Les Bischoff
>I have a pattern etched in this stair riser. You'll have to look at the picture to see it. What I'm looking for is a way to highlight the etching that's not burnt or colored in by hand (ie a marker, crayon,sharpie. I'm sure I've seen a method where you prestain the etching or something similar to that but I can't recall the method and haven't had any luck finding something like it on google or here on WC's search. Ultimately the whole piece will be stained and/or sealed in poly. I'm thinking the etch will just get lost with stain but just plain poly might show it via shadow. For some further details the etch is done with a v groove router bit to a 1/16" deep on a CNC router. This is the riser for treads in a spiral staircase the company I work for makes. We're trying to kick it up a notch or two. Thanks for any and all input
Re: Finishing help
Re: Finishing help
Matt Byrne
>You can buy wide roll masking from Avery. Finish the entire piece first apply the mask rout desing with cnc then paint routed area and remove mask. You will get nice sharp edges.
check out
http://vectric.com/forum/viewtopic.php?t=336
Re: Finishing help
Re: Finishing help
Charles Sharp
>What if you flooded it in stain, wiped off the top real quick and let the stain in the carving sit? Or perhaps sand the top surface after staining.
Re: Finishing help
Re: Finishing help
Les Bischoff
>That's kind of where we're going but I guess it all boils down to just trying it out. We'll see if anybody else chimes in with another idea.
Re: Finishing help
Re: Finishing help
Les Bischoff
>Masking doesn't work for us as we don't finish the part just sand. It's left to the installer to stain/seal.
Re: Finishing help
Re: Finishing help
Glaze It
>Give the tread an initial coat of whatever you'd like. Sealcoat .... Poly if that's what will be there in the end as a top coat.
After the first coat is dry, scuff it up and apply a coat of the gel stain of your choice. Darker would make sense. Wipe the stain off leaving more behind in the pattern. You can use a brush, dabbing it into the pattern, to soften what's left behind. The pattern will then stand out from the rest.
Now .... several things. This can be done even if you intend to stain the entire tread. Stain it, then seal it, then apply the gel stain. I've used gel stain as an example, but the gel stain is acting as a glaze. A glaze is a layer of color applied over sealer as opposed to raw wood. You could certainly use a premixed glaze, but the gel stain will work, especially as a trial to see if it yields what you're after.
Experiment with the seal coat to find out how heavy it needs to be. It it's too thin the stain may penetrate too much.
After the glaze is dry it'll need to be locked in before top coating. A thin coat of Sealcoat from Zinser will handle this nicely. Don't over brush it or you'll disturb the glaze. Spray would be best, but not required. It you try and go straight to top coat, especially brushing, you'll redisolve the glaze and make a mess. Well, maybe not a mess, but it'll all bleed together.
Any research on glazing will give a world of information including illustrations I'd bet.
Experiment a lot before hand.
Re: Finishing help
Re: Finishing help
bill tindal, E.TN
>If you put a wash coat of shellac on the piece before making the pattern and then stained, the pattern would take more stain and be enhanced.
Re: Finishing help
Re: Finishing help
Robin Corell in Atacsadero CA
>There is really not much need to do anything to make it stand out. routing the design opened up the end grain which is going to show much darker than the face grain once the stain is applied. The same will apply to a claer finish as well, though it will not be quite as dramatic.
My first thought though is not the finish but the actual routing. Your design is really not taking full advantage of what a CNC can do. Why are all the leaves identical and why arn't you varying the z axis more? If you keep the tool moving as you retract it on the center vein of the leaf it will make a pleasing point rather than an abrupt round termination of the line.
Robin Corell
Re: Finishing help
Wrong juncture
Michael Dresdner
>Enhancing the carving is VERY easy for the finisher as the third step, but for you to do it prior to that and still leave the finisher all possible staining options is both difficult and counterproductive.
Once it is installed, stained, and thoroughly sealed, all the finisher needs to do is wipe some thick glaze over the carvings. It will all wipe off of the completely sealed flats and leave rich color in the recess. Make the glaze from acrylic paints (like the ones you find in small bottles in the craft store, or sold as "100% acrylic trim paint") and reduce it with water. Acrylic will stick to any finish, and any finish can go over it, so there are no limits on the finisher. Be certain it is acrylic and not latex.
The worst case scenario, if your finisher (installer?) won't do it, is to simply come in after his sealer coat and first top coat are on and dry and do it yourself. It will take all of one minute per riser and will dry in under an hour.
Re: Finishing help
Re: Wrong juncture
Les Bischoff
>Thanks Michael. I didn't think about a glaze after it's sealed! That's why I figured I'd ask here with the vast knowledge of all the various WC'ers.
Re: Finishing help
Re: Finishing help
Pete LaBelle
>These signs you have hanging on your lamp post with family name or house number have been seen made at craft shows. Route in the letters, a quick coat of quick dry black spray paint, allow to dry, then sand off the surface.
My thought would be to leave it as is. Too much accenting of it may make the work look more like a carnival truck.
Re: Finishing help
Re: Finishing help
Les Bischoff
>Just to follow up. I appreciate everyone's advice. Like I said in my original message we don't do any finishing here but we need to be able to tell/show someone their choices when it comes to finishing. Here's the first one which is done with poly only.
Re: Finishing help
Re: Finishing help
Les Bischoff
>This is the glazed one. One coat of poly, one coat of acrylic paint in the engraving then another coat of poly. Brown just seemed like a natural contrast color here. But I would think any color would work fine.
Re: Finishing help
Re: Finishing help
Les Bischoff
>Here's one stained then poly. The dark stain really jumps out. I wasnt expecting it to darken so much. But it did the job brilliantly. This particular stain is "Candlelight" by General Finishes.
Re: Finishing help
Re: Finishing help
Les Bischoff
>This one is done with a minwax honey oak stain that has the poly already in it. I forget what they call it. Not too crazy the way this one came out but it could be just the light color of the stain.
