Why is it? OT
Gary Evans Tallassee, TN
>Over the nearly thirty years we've lived in our cabin, I have done a lot of plumbing work, mostly with plastic pipe. Initially, when we only had wood heat and gravity-fed water, we had trouble with the copper freezing, so at one point, I tore it all out and replaced with pvc and cpvc. Some years later, we had a well dug, so more plumbing, all with plastic. Later still, we added on two stories in the back with two brand new bathrooms, all plumbed with plastic pipe.
Add to that the fact that I have spent much of the past several years doing remodeling work for others, including a lot of plumbing. With outside jobs like that, I know that I always buy extra fittings just to be safe.
So, WHY IS IT that I don't have one single extra 1/2" cpvc coupling?
I am redoing my bathroom cabinet in the main bath which requires re-jiggering the supply pipes, as well as the drain. I drove the 50 miles roundtrip to Home Depot yesterday and bought all the fittings I need, including two 1/2" couplings. I get home and discover that the pipes have to be configured a different way than I first envisioned, so I need 3 couplings instead of two.
I have spent hours now searching the house and the shop and can't find one single 1/2" cpvc fitting anywhere! I can only assume that extra fittings end up in the same place as those socks that are lost in the dryer. Oh well. Off to Homey Depot again today, I guess.
Thanks for letting me vent.
Gary
