lubing ways on table saw
wayne
>Am trying to find a lubracant for a table saw. I have a Boyce Crane saw but need to lubricate the 45 ways. I have tried spray dry luibs but they don't seem to last vary long.
Re: lubing ways on table saw
Rob Stokes in North Vancouver
>Hi Wayne - I'm curious which Boice Crane saw you have? I've got a restored 1955 Master Monotrol (10") cabinet saw. We're still getting to know each other, but it's fast becoming a trusted steed.
As for lube - I've using a spray (aerosol) graphite. It seems to be working, but it needs applying fairly regularly and it's a bit messy. If here's an alternate, I'm all ears.
Here's an earlier pic. It's since had miter slot extensions installed as well as a router table insert (Rockler) in the outfeed table.
Oh - if your blade inserts are the same shape as mine, let me know. I've built a set of fixtures that allow me to make one piece zero clearance inserts out of 1/2" thick material (I'm using a cellulose reinforced phenolic resin). The pic shows an early template installed, not the actual insert.
Rob
wayne
>Rob
I don't have any idea as to how old mine is, it is an 8" that I had the arbor turned down to 5/8" from 3/4". It has an open frame with a steel enclosed bottom. I'll send you a pic tonight. I have tried powdered graphite, do they make one in an aersol can?? I purchased it in 73 for 125 and it has been worth every penny though the fence cost twice as much as the saw. For some reason I figure it was made in the 40's or 50's. I know that parts cannot be had. I had some parts machined for the blade raising mech. luckey I knew the machinest. My table insert is square about 5"x12" which I make out 3/4" UHMW or what ever it is called.
Wayne
