Stripping bark from logs
Tom Dunlap
>A number of years ago I cut down a HUGE ironwood [Ostrya virginiana] that has a wonderful trunk configuration. Now its time to strip the bark and make it into a table base. The bark on the ironwood isn't too thick so it comes off [sorta] easy. The next project is to take an oak limb shaped in an "X" and make a coat rack that will lean against the wall.
Over the years I've stripped bark in several ways. Drawknives, chisels, 4" angle grinder with a variety of grits, 6" angle grinder too. None of the jobs have been very easy.
Today I bought one of the coarse fiber grit wheels that chucks into a drill to try out.
My experience has shown that I need to use a coarse grit to get off the bark. That leads to many levels of resanding to smooth out the grind marks.
Does anyone have any better solutions?
Re: Stripping bark from logs
DB
>I use a tool called a bark spud to strip the bark off of logs. A bark spud looks like a large long handled chisel. Try looking at a logging supply store.
the spud is your friend
Tom Sontag - St. Louis
>The spud is the correct tool, designed for the job. But my limited experience suggests that winter cut logs are still a pain to debark.
>A friend who does timber framing alternates between a spud and a timber framing drawknife. I only do small log sections, so I use a drawknife. Both look like a lot of work to me :). Good luck.
>Since you are doing relatively small amounts wonder if you could use a power washer? Just throwing out ideas. If you had a really powerful one it might work.
I'm not sure I recommend it though. I used one to clean the dirt off a stump I wanted to turn on my lathe. Not sure I understand precisely how it happened, but it appeared to remove the dirt from the stump and apply it directly to me. I had more dirt on me than had been on the stump. Thought about turning the power washer on myself.
Keith Newton
>Everybody have given you good advice, but waiting for Spring is the most important. When the cells first divide, they are very thin walled, so it is easier to just rip the bark off then rather than now while they are full and thick.
I usually make a slit in the bark, and peel around the tree, not up and down it. I have made and tried a lot of different tools for this. A flat nail bar works pretty good, but any steel tool will leave a black stain when it touches certain woods. Although you may be able to remove it with oxalic acid, I would rather not deal with that, so I made some spuds out of a tough slick plastic that works pretty good.
The spud that I made is from nylatron, and is about 1" x 1.5" x 32", and is sharpened with a 3" long bevel on one side, and a short rounding to the edge, with a barb cut about 1/4" back from the edge. The rounding allows it to slip in between the bark, without digging into the wood, and the barb keeps it from slipping back out when you try to lever out against the trunk.
One last thing. Some woods like maple, will show a bruise where any tool crushes the cambium. I was stripping a big hollow maple once to use for a stair. I didn't want to have to go back and bleach that out later, so I thought I would try what my mom did to keep bananas from turning in fruit salad, and it worked. I filled a spray bottle with lemon juice, and squirted the bruises with that, scrubbed it with a finger-nail brush, then hosed it off. It came out really nice.
Oh by the way, I have even made spuds out of wood, but they dull fast.
Howard Norman-Prescott, AZ
>Tom, I live in a log house where the bark was removed from the logs on site. The logs are Ponderosa Pine and the bark was removed with a "spud". The one used here was about six feet long and the chisel part was about two inches wide. The log portion of the house is about 3,000 sq ft so a lot of bark to remove. For the smaller logs used for railing a heavy draw knife was used. I would guess that the draw knife was about 1/4" thick and 12-15" long.
Howard
Abrasives and kinves
Tom Dunlap
>Thanks for the insights. The ironwood was cut down years ago but I left the bark on thinking that it might slow down the drying...and...knowing that it would be a challenge to strip later...read, now :)
This stump has very few cracks in it so I might have stumbled onto something.
Spuds aren't really the answer because of the irregular shape. A drawknife and my 4" or 6" angle grinders will get a workout.
I tried using a pressure washer one time. It didn't work very well. When I talked about this with a buddy who had worked in a production sawmill he told me that they used a very high pressure water jet to debark some of the logs. Much higher PSI than I could afford to own.
Hearing the story about debarking a stump sounds too familiar. I've done the same thing before with the same results :) I've used a pressure washer to 'excavate' the soil to expose girdling roots around the trunk. What a mess! But the trees have all started to grow better after the girdling roots were removed. Now there are high pressure air nozzle tools that work much better.
