Re: Cherry Platter Quandry
John McGaw
>I take it that you are objecting to the tenon/foot at the bottom of the platter? The traditional way to remove it or to simply shape the bottom is to reverse chuck the platter and turn it off. But if you don't have the jaws for your chuck to to it and you don't want to make them there is always the alternative of the belt sander. Or, for that matter, any other tool you might use to remove a lump from any board.
I've always been of the "old school" which turns the tenon off and then adds something to show that it was really turned off and not removed by other means -- a couple of finely incised grooves if nothing else. But given the practice of many turners today of "carving" their turned objects with anything up to and including a chainsaw I don't see where a little bit of sanding would hurt anything.
