OT: Best way to remove bathtub caulk?
wilbur
>Our bathroom had a bit of a mildew problem in the bathtub when we moved into our house 2 years ago. We've been able to get rid of most of the mildew, except for the caulk line between the tile and the tub. I'm at the point where I'm ready to take the caulk out and replace it.
Any suggestions on the best way to get the old caulk out? My one concern is that this task may take a lot of time. Since this is our main bathroom, I can't afford to have it out of commission for more than one day. (Of course, this may be the excuse I need to buy a Fein Multimaster.)
Re: OT: Best way to remove bathtub caulk?
Jesper, Denmark
Sharp uyility knife and patience.
Jesper, Denmark
Jesper, Denmark
Re: Utility, can't spell worth a damn....
Jesper, Denmark
Thought You Had Just Substituted a Danish Word :>
Robert Hutchins
Jesper, Denmark
Re: Thought You Had Just Substituted a Danish Word
Jesper, Denmark
>Should have done - it's called a Stanley kniv!
Have You Been Carrying On with the Crowd in . . .
Robert Hutchins
>Copenhagen? Looks like things got a little out of hand with some kids there. BBC World News reported that 20-25% of those arrested were foreigners. Is there poltitical turmoil among Danish youth?
I ask because my daughter is talking about visiting Europe this summer or fall. She's in her mid 20's; so I don't know if the 'youth' in Copenhagen are her age or younger.
Regards,
BobH
Patience -- don't have time for that
wilbur
>Thanks, I had already thought about that, but as I said above, time and patience isn't something that is in short supply for this particular project.
Any time saving tips would be greatly appreciated.
Ceramic Tile and Grout?
Robert Hutchins
>Hello wilbur!
If you are working on grout with ceramic tile, patience is the only solution. If you hurry this job - regardless the tool - you will wind up with chipped tile. DAMHIKT.
I've used a screwdriver with the bit ground to round the corners, a Dremel with various bits, and something called a grout saw (a hand tool). The Dremel worked but raised a lot of dust and would damage the tile if it slipped (remark the warning about patience, above). The grout saw worked well between 2 pieces of tile but not so well between tile and tub.
All of these problems could easily be put down to bad technique - or none at all - on my part. Most likely the tools are blameless.
If you are removing caulking - not grout - try using the same kind of heat gun you would use to remove paint. It should soften right up and come out fairly easily. Don't overheat it to make it too plastic. Experimentation will find the right amount. Use whatever tools you have at hand or care to modify to make groove scrapers and hooks to pull the plasticized caulking out.
Another caution: if you don't do anything to kill the mildew, you will repeat this job sooner than you'd like. DAMHIKTE. My best results came after removing the caulking, spraying down with bleach/water mixture and allowing it to dry to the touch, then wiping out with clean damp cloth (wrapped around small screwdriver). The second time, I repeated the Clorox-spray-allow-to-dry-then-wipe-up routing 3 times.
Then I sold the house and moved. Well, I sold and move; but it was about 8 months later. Don't know if the mildew came back after the last treatment, but it didn't come back in a few weeks like it did before.
Use a good latex caulking with mildewcide made specifically for tub and shower enclosures.
HTH
BobH
Jesper, Denmark
Not me....
Jesper, Denmark
>We are about 60 miles from Copenhagen. The issue is the sale and demolition of a building used by youths for alternative cultural activities. Sorta like a 2007 version of hippies throwing bricks at the police in frustration.
I about 4 days of rioting only activists have been hurt - mostly by bricks from their own. The population in the area is getting mad at the rioters and have taken to catching them, removing their trousers for a good spanking - and sent them back on the street -- sans trousers. It is cold and wet weather here. Trouserless rioters tend to be rather timid.
Your daughter can quite safely travel here in the summer and fall. Copenhagen, like any other big city has some trouble spots, but they are easily identifiable for a sensible person and quite benign compared to the South Side of Chicago or similar areas in other US cities.
Five and one tool and....
SanMan
>....a beer or three.
No one looking over your shoulder is good too!
SM
I Love the Idea of Taking Their Trousers!
Robert Hutchins
>Sounds like a perfect solution to hooliganism - injures only their self esteem and credibility with like-minded miscreants.
Thanks for the information. I'll pass it along to the traveler.
BobH
