Super Dado
Super Dado
Super Dado
Ells in Boulder
>I recently upgraded from an old adjustable dado blade to Freud Super Dado set to get sharper and smoother cuts. I was disappointed to find that there is enough looseness in the chippers' center holes (dia. slightly too large) so as to give very a uneven bottom in the dado cut, no better than the old Craftsman adjustable. Did I get a bad set of chippers? The main, end, blades fit fine.
Ells
Re: Super Dado
Do you have a caliper mic?
John in New Mexico
>If the holes in the chippers mic bigger than the holes in the blades, then you've got bad chippers. Otherwise, you may have a worn arbor, or it may just be variation in the dado set, though I'd expect somewhat better from this manufacturer.
John
Re: Super Dado
Re: Do you have a caliper mic? -solved
Ells in Boulder
>After posting, I thought about mic'ing the holes (got a new digital for Xmas) and noticed a slight suggestion of only 0.002-.004" oversize on the chippers. Rechecked the end blade and it too came in about the same. Then I looked closer at the arbor and there it is, there is a shoulder that the blade usually sets on, and the first dado. Rest is thread that is slightly smaller. Need some sort of sleeve.
Ells
Re: Super Dado
What saw?
Hoa Dinh
>The problem with the variation in arbor diameter is a known defect of some Craftsman saws made by Emerson.
Some of the early Ridgid saws also have this problem.
If you saw is a Ridgid, contact them. I've heard that they send out replacement arbors free of charge.
If it is a Craftsman, you're on your own. I've heard that it could be fixed with epoxy.
-- Hoa
Re: Super Dado
Charles M
>The tolerance on Freud 5/8" bore dimensions is 0.625" +0.0007"/-0.0000". The result is that the hole will be no smaller than 0.6250" and no larger than 0.6257". I would wager that the saw is either a Craftsman or Ridgid - both are known to have arbors as you described.
Re: Super Dado
Re: What saw?
Ells in Boulder
>It's an old Craftsman (25-years) that has served me very well, up to this. S. Dado is worth more than the saw. I guess I know my next move!
Ells
