Veritas - Innovation in Tools
Jointer Blade Question
Carmen
>I'm in the process of replacing the 4 blades in my Bridgewood jointer. Unfortunately, the alignment tool that came with it is pretty useless. So I was thinking of using a magnetic tool to align the blades prperly.
When I do so, do I just ignore the jack screws and just tighten up on the clamping screws that hold the blades in position, or do I first turn the jack screws util I "feel" them seat against the bottom of the blades and then tighten the clamping screws?
Re: Jointer Blade Question
John in New Mexico
>A lot of machines seem to use springs instead of jack screws, I've even known people to replace the jacks with springs. Either way should work fine, both are, I would suspect, a lot easier that trying to set the height by holding the blade up and tightening the clamps. Jack screws are really handy for setting blades using a dial indicator, but thats kind of overkill on a jointer. I made magnetic jigs out of some pieces of teak and 6 rare earth magnets. Two sticks, planed flat, magnet at each end and one in the middle, all set slightly below the surface and epoxied in. The way I use them the magnets are mainly to hold the sticks down, though you could use the one on the end at the blades to hold up a blade w/o springs. I tend to set the height such that turning the head slightly catches the sticks and pulls them forward a little- say less than 1/8".
Good luck with it,
John
Carmen
>Thanks, JOhn. I've also seen a blade setting jig like the one you made. For now I'm using the magnetic feather board tools to do the job. I'll be making a set for myself also!
David Dean
>Check out www.dispozablade.com They have a knife system that will solve your problem.
