Re: OT: Well pump Long explanation
Larry Clinton At Frankfort (Central)., Indiana
>If you have a "Bladder" tank used as a reservoir / pressure tank, you should understand how it works - makes it easy to service if you know exactly what is happening. The Bladder in the tank is somewhat like a hot water bottle. The water is pumped into the bladder, expanding it until it almost fills the tank. When set up properly, the "tank" outside the bladder is pressurized at or just below the lower set point of your pressure switch on the pump (the point where the pump turns on, per the information Del posted. When the pump is off, (reached pressure) and you open a faucet, the pressure in the reservoir tank forces the bladder to become smaller, forcing the water out. You can use almost as much water as the reservoir holds as the pressure will remain above the low set point of the switch that turns your pump on. These usually don't require service (adding air pressure for several years. Your tank must have a small -pinhole- leak in the bladder. Replacement is very simple as there is usually only one pipe fitting into the tank. You can replace it with any size bladder or diaphragm tank. The larger the tank the longer you can run water between pump starts. You can also add additional tanks anywhere in the cold water system by adding a Tee and plumbing in the additional tank. Be sure the replacement or additional tank has the pressure set as above. The old tanks - without a diaphragm or bladder used a float and allowed air to be injected into the tank. When the "float" in the tank reached a high level, it allowed air to be sucked into the jet (or piston) pump through a small (usually 1/4 or 3/16") line from the tank to the pump head. These did not allow as much water to be used before the pump restarted for the same size tank. A much smaller diaphragm / bladder tank serves the same function.
