OT----Plastic piping to steel fitting?
Gary Evans Tallassee, TN
>Hi all,
Apologies to those who object to off topic posts.
Two heating seasons ago I installed a wood furnace with an integral water coil. I plumbed the coil to a pre-heating tank with 3/4" cpvc. The pre-heating tank is a small water heater tank. The source and outlet water are plumbed with pvc and cpvc, respectively. I have had problems with the plastic to steel joints leaking. Recently, I overcoated those joints with fiber-reinforced bondo. It worked well for some of the joints, some still leak with changing temperatures.
I'd really be interested to know how to make these joints waterproof over a temperature range of 40 to 120 degrees.
Thanks much,
Gary
