Poly over lacquer
Poly over lacquer
Poly over lacquer
Tom Norton
>I need to put a fresh finish coat on a set of stairs. There are red oak stained dark with laquer as the finish. It was done about 20 years ago. I am wanting to use a polyurethane as a freshing up coat as the stringers and risers are going to be enameled.
What prep is required?
Thanks
Re: Poly over lacquer
jan derr
>i believe you can if you sand thoroughly with 220 to key in the poly making sure you knock off all of the old finish thats not adereing well. I would also use a recomended sanding sealer for the first coat.
Call or email the manufacturer of the product you intend to use and ask them, they can be very helpul and have even paid me a visit to see the problem first hand.
jan-asheville, nc
