New 14" Bandsaw Tires--- To Glue Or Not To Glue?
Dave Morris
>...That is the question.
Seems like all the research I'm finding on re-habbing and fine-tuning bandsaws sez to glue the tires to the wheel when you're putting some new shoes on the saw. The saw in question is a Jet 14", the wheels are already crowned from the factory, and the new tires fit between the *rims* of the wheel on each side of the crown.
Jet didn't include any adhesive with the tires when I ordered them, and said it wasn't needed when I called to ask for some.
So, is glue only needed on larger saws with flat wheels (no crowning of the metal or rim to hold the tire in place)? If I glue on the new skins, what type of adhesive is preferable? Does using glue mean balancing the wheel is more of a necessity, and/or using a jig to grind/sand/cut the rubber to insure concentricity of the tire where it touches the blade? Thanks for clearing up my confusion. I'm simply wondering what's what in this particular case.
BTW-- I'm making progress on this saw resto when I can find a spare hour here and there. So far, it's been fun, but living in a small town can make even the usual things like getting the new bearings pressed a lesson in patience and determination. Grrrr...
Dave--- who, then again, likes a challenge every now and then ;-)
