3 phase motor question
jan derr
>I just got an old American Woodworking Machinery 16" jointer and she ain't running right. She came with the original motor, perhaps a 1920's vintage, 9 wire delta three phase wired for 440-480. I wired it for 240 and when I hit the switch she makes a whole lot of noise and the cutter spins at may be 200 rpm. Ive made all the necessary voltage checks at the magnetic starter with good results. So all symptoms point to the motor. I removed the motor, it's a direct drive 7.5 horse, and noticed some shimming around the mounting flange, and then when I pulled the housing off the stator came with it, but the rotor remained attached to the cutter head.
Now I am wondering; could the allignment of the stator to the rotor, hence the shims somebody put there, give the symptoms of an under powered motor?
thanks for any info
jan in asheville, nc
Re: 3 phase motor question
jan derr
>oh! i might mention that I have 3phase power in my shop from the street and have successfully wired my other 3 phase machines.
Jim Swank
>Sounds like you've got a bad connection or open phase winding. Doublecheck your wiring, then check winding resistance with an ohmmeter if you can.
Scott Banbury
>The motors on these direct drive Americans use the inboard cutter head bearing to support the entirety of the rotor. The shimming was probably there to align the motor casing properly.
If the motor was wired for 480, it needs to be rewired for your 220.
jan derr
>actually the rotor is bolted to the cutter shaft wich is carried by its pillow block monted bearings, not babbit. The motor housing wich holds the stator windings is mounted separately to the jointer's chassis. So there is room for misalignment.
I definitely have it wired properly for the lower, 240, 3 phase voltage.
Jan avlnc
Keith Newton
>I would take all of the wires loose from the motor, and check the volts on each leg to ground or N and make sure that there is no drop from what you read on the top side of the starter. If it is the same, then the problem is probably in the motor, which you can have rebuilt.
However, you can have the end of the cutter shaft turned to fit a standard pulley, and then use a motor mounted on the floor, or underneath. I can find good used three phase motors in that size all of the time very cheap.
If you find that you are going to rebuild the motor, Without knowing the sharpness angle of your cutter-head, nor the type of work that you plan to do, I will just say that if it were mine, I would think of going up to a 10 hp, because I only work with hardwoods, and use a face bevel to reduce the sharpness, or hook angle to 10� which will eliminate any tear-out when the grain changes against the feed, but the trade-off is that this requires more power.
Re: 3 phase motor question *LINK*
Phil Smith
>Suggest that you post the question over on OWWM.org site. Lots of experience over there on getting these old machines up and running.
Lots of historical data at OWWM.com
http://www.owwm.org/
