Re: Need Template Routing Info.
Jesse in New Mexico
>I think the Colonel hit the nail on the head. I would add a couple of thoughts.
Be sure to route with the grain to avoid tearout, this may require a climb cut on curved pieces.
If your stock is thick, you can remove the template and tape it to the other face, then route from that side.
Take your time with the template. Any little glitch will show up in each part you make.
If your part is symmetrical, the template should only cover half, route that half, then flip it over for guaranteed symmetry.
When you are happy with your template, make a few copies. Sh** happens and you don't want to have to start over from scratch. DAMHIKT :^)
