THE WOODRAT IS BACK!
PIN CHUCK
PIN CHUCK
PIN CHUCK
Ed Felix
>My lathe is a Powermatic 3520B. The spindle nose is 1-1/4 x 8. I'm looking to buy a pin chuck so I can try to spin some Alabaster, any idea's where I can buy one. Thanks, Ed
Re: PIN CHUCK
Re: PIN CHUCK
Stuart Johnson
>Packards carries a 3/8" that you use with a drill chuck. If you need something larger you could make one using a piece of steel rod. Grind a flat and use a nail for the pin. Hold it in your 4 jaw chuck.
Someone over on the turning board might have additional suggestions.
Re: PIN CHUCK
Re: PIN CHUCK *LINK*
Phil Joines Krum, Tx
>You'll get more responces if you post on the turning forum. Third chioce doun under Messageboards on the left.
You lathe also has a #2 Morse Taper. Collets are available at the link for about $10. You want the collet, 2MT. Select the size you like and make a pin to fit. You'll also need a piece of 3/8 all thread and a nut W washer to pull the collett tight.
http://www.littlemachineshop.com/products/product_search.php?critFast=collet+2mt&B1=Product+Search
