Need Delta Technical Support
Steven Mellott
>Does anyone from Delta monitor this website? I've sent several emails to the Delta Tech Support Group and can't get a response. My questions pertain to the 10" 2 HP Left Tilt Tilting Arbor Saw (Model 36-755). First, will the Delta splitter 1349941 fit this saw? Second, can you run this saw on a 20 amp circuit? The manual says that you should run it on a 15 amp circuit, but I don't know if that is intended to be a maximum or minimum. I don't know if the motor (model 82-010 which draws 8.3 amps at 220v) has overload protection built into it or not. I'd like to run it on a 20 amp circuit, but not if it's going to jeopardize the motor. Thanks for your help with this.
