Great jig...once you get use to it.
Craig Daymon
>I have a similar jig and I always use the same size blade, a 1/8" kerf Freud Rip blade (because it has a flat top tooth). The rod is 3/8"-16, so 2 revolutions moves the cut 1/8" more. If I want 1/2" teeth, I cut, turn twice, cut, turn twice, cut, turn twice, cut. That's 4 cuts with a 1/8" kerf giving me a 1/2" opening. Now I turn twice more to get past my last cut position for the opening. Then I turn the handle 8 times to move 1/2" without cutting, to the next position I want to cut. Just repeat the process as necessary.
For the joining board, Turn 8 times, moving the first cut position 1/2" (or eight 1/16ths), before making your first cut to start. It might help to make a sketch and write down your required turns. That's what I did for my desk organizer where I varied the width of the teeth.
For me, it's less about the width of the blade and more about how much I move my cut with each turn. The width only comes into play when moving over uncut areas to the next starting position.
-Craig
