Dowel rod
Dowel rod
Dowel rod
Doug Ridley
>I need to drill 3 or 4 holes in a 1/4" dowel 18" long and they have to line up perfectly. I need ideas on how to do this.
Re: Dowel rod
Re: Dowel rod
jmohnike
>You can try this.
Clamp a straight edge fence to your drill press table apx 1/2" off center.
Rip a board 1" wide apx 20" long.
Insert a 1/4 router corebox bid in your drill press.
Lock the quill so that the bit will cut 1/8-3/16 deep into the board you ripped.
Useing firm pressure route a goove in the 20" board.
Set your dowel into the groove and tape to board, keep tape off the side that rides against the fence and bottom. Drill holes and cut to length.
Hope this helps.
Joe
Re: Dowel rod
Re: Dowel rod
>I like the idea of using the core box bit in the DP, I would not have thought of that.
What I would have done is cut a vee grove in the piece of scrap on the TS. Then I would have set up the DP with a fence and, using a 1/16" bit as a pointer I would have aligned the vee grove with the chuck. Clamp the fence down. Tape the dowel in the vee and with the correct bit in the chuck, drill the holes.
Same as above, but does not require the core box bit. The core box bit technique automatically aligns the groove. Neat Idea.
Re: Dowel rod
Re: Dowel rod
Doug Ridley
>Thanks Joe and Barry. Now if this old geezer can figure all that out I'll get to it. Weak minds have trouble deciphering stuff sometimes.
Re: Dowel rod
Re: Dowel rod
Doug Ridley
>Worked perfectly! Tnanks again.
Doug
Re: Dowel rod
I do it a LOT !
s.mackay@worldnet.att.net
>I've got several jigs out of oak I keep around in different sizes and lengths. Set your TS at 45 and adjust the depth for the dowel size. Run it through both sides to form the "V". Make sure your jig is thick enough so you dont hit the table on the drill press. As above set up a fence and clamp your dowel in the jig. I got fancy and scored scales down the sides so I don't have to try and hold a ruler on a round dowel.
