It can be very difficult
Lee Grindinger
>Burls, other figured woods, and marquetry/parquetry patterns can go wild when moisture hits them. Hammer veneering entails applying hot hide glue to both sides which helps some but not entirely since figured woods and burls expand in different directions. Some pieced together veneers need refitting while applying since it's impossible to un-expand them. I've had to recut seams to accommodate this expanision when hammer veneering and have pretty much quit using this method unles it's a small area and I've got some glue ready. The up side to hammer veneering is that as long as there's water and heat there's no rush or time limit as there is with PVA.
The easiest way is to get a press. A vacuum press is a great investment if you're going to use veneers a lot. In fact, Tommy, in your case the purchase of a vacuum press WILL change the way you design and build furniture for the better.
Lee
